tire hmmmm
Old Feb 14, 2002 | 05:55 PM
silentneko's Avatar
tire hmmmm
hey guys,
I just got 2 tire put on the front of my car, they are 225/60/16, I know they are not the right size but I got them because I had to and they are real cheap, they are goodyears. any way there is a noise the tires make that sounds like a hmmm. they don't shake around or bounce, they just hum, what can cause this?
Old Feb 14, 2002 | 06:01 PM
ronterry's Avatar
Car: '94 Corvette
Different treads make different noices. It's that simple.
Alot of times you see tires reviewed by traction, wear, and tread noise.
They might wear in quieter.
BTW: my Impala makes that hmmm noise
Ron
Old Feb 14, 2002 | 06:14 PM
blue91rs's Avatar
Holy crap, which rims do you have?
I did not know that you could go smaller than 245 on those rims, very interesting.
Which type of goodyears do you have?
Old Feb 14, 2002 | 07:45 PM
Hellraiser's Avatar
I've installed both michelin xw4's and bfgoodrich touring t/a's
in the past (for customers at work), in a 225/60/16. They seemed to fit fine with the stock rims for firebird/trans am, but actually sit alot taller than a 245/50/16 would. Probably a bad idea if your suspension might be sagging from age....
FYI - For not much more than the above mentioned tires, you can get a BFGoodrich Radial T/A in a 245/50/16... should be 90 dollars or less each.
**end sales pitch**
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
