ok teach me my terms
Old Feb 26, 2002 | 05:09 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
LS1 LT1 LO3 L98 whats difference between em?
Old Feb 26, 2002 | 05:16 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
LS1 is the third generation v8 found in the 1998-up fbodies and corvettes (vette might have had it in 97, not sure). The new truck engines (4800, 5300, 6000) are similar to this engine.
LT1 is the second gen v8 found in 92-97 vette and 93-97 fbodies
L98 is a first gen roller 350 sbc with TPI fuel injection. This has the same basic design as all small block chevys since 1957. Many small changes over the years but same basic design.
I think LO3 is the TPI 305. Also a first gen roller block.
Old Feb 26, 2002 | 05:53 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
he's right about everything except the LO3. The LO3 was the enemic 305 TBI, rated at 170 hp. It could be found in 88-92 f-bodies and some trucks.
Old Feb 26, 2002 | 06:00 PM
Vader's Avatar
Wasp,
What SlickRock is saying is that those designations are the factory Regular Production Option codes (RPO codes) for the engines installed in GM vehicles. Each one is a "family" and there are slight variations among each family. The LT1 in a Corvette got a slightly different camshaft than those in the 'B' cars, even though the engine was still classified as RPO code LT1.
Here are some examples of GM RPO codes for engines:
Old Feb 26, 2002 | 06:05 PM
wasp's Avatar
man that vader is one sharp ***** thnx
Old Feb 26, 2002 | 08:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Holy crap, please say that avatar is you..
Old Feb 26, 2002 | 08:14 PM
cfabe's Avatar
Vader,
Whats that LZR DOHC v8? I've never heard of such a beast.
Old Feb 26, 2002 | 08:24 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Just one more correction, the last year for LT1 in the vettes was 96 I believe. Didn't the LS1 start in 97?
Old Feb 26, 2002 | 08:59 PM
rezinn's Avatar
LZ7 is a corvette motor, LT5 was left out, maybe because it would be the same on that chart as the LZ7.
Old Feb 26, 2002 | 09:00 PM
rezinn's Avatar
LS1 was put into the fbody in 98, so it may have been in the 97 vette.
Old Feb 26, 2002 | 09:40 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
The Vette got the LS1 in '97, a year before F-Bodies. It also got the LT1 in '92, a year before F-Bodies.
Old Feb 26, 2002 | 11:19 PM
Vader's Avatar
Originally posted by cfabe
Vader,
That is an old chart from about 1993. That was the VIN 'J' engine in the Corvette, also known as the LT5. It displaced a bit over 348 inches with a 3.900" bore and 3.66" stroke. Each of the heads had two camshafts, with four valves per cylinder. It was built for Chevrolet by Kiekhaffer/Mercury Marine, and was balanced for high RPM operation even with the longer stroke. As I recall, it was only offered for two years in the ZR-1 Corvettes.
The surprising thing is that a lot of the case design and dimensions of the LS1 and LS6 engines is amazingly close to the design of this engine. Even the deck heights are the same. It appears that the relationship between Chevrolet and Mercury Marine was mutually beneficial.
Old Feb 27, 2002 | 10:47 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the LT5 came in ZR-1 vettes from 1990-1995
Old Feb 27, 2002 | 11:11 AM
Vader's Avatar
Thanks for the correction. I've never been close to the hood of that many 'Vettes, and most ZR-1s I've seen have only been from the rear....
Old Feb 27, 2002 | 11:47 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
On the 'E' entry, shouldn't that be L03 rather than L89? I've never heard of the L89...is that a typo or are there two different RPO codes for throttle body injected 305s?
Old Feb 27, 2002 | 04:57 PM
wasp's Avatar
vader, just curious what you do for a living?
86IROC112
Nov 27, 2015 09:54 AM
hartsmike
Oct 4, 2015 01:00 PM
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
Ragtop Man
Sep 12, 2015 12:23 AM
