code 42
Old Mar 7, 2002 | 05:44 PM
Vikingbrew's Avatar
code 42
what is the most common repair for code 42?
i found this somewhere:
Electronic Spark Timing (EST) circuit - open or shorted to ground during engine run
OR Direct Ignition System (DIS) fault - bypass circuit open or shorted ground during engine run
OR Fuel Cutoff Relay Circuit - open or shorted to ground
how do i fix the problem once its diagnosed?
Old Mar 10, 2002 | 09:52 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
I got the same error code today and i have no clue what it takes to fix. My car lurches at slow speeds and i just replaced the MAF sensor and other things! Let me know if you figure it out, i'm clueless , thanks in advance, wish i could help
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
