Constant running fan...
Old Mar 11, 2002 | 06:39 PM
myh0's Avatar
anyone know how to make the fan run constanly for example right when you out it in ignition the fan is already running..??
Old Mar 11, 2002 | 06:52 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
hot wire the red wire going to the fan relay to a live one when the ignition is on.
Old Mar 11, 2002 | 07:14 PM
Omar's Avatar
The red wire is already hot with the key on. You need to ground the relay. Usually a green wire.
Your specific year and make would help.
Old Mar 11, 2002 | 08:50 PM
myh0's Avatar
i have a 88 Iroc 5.7L TPI
Old Mar 11, 2002 | 11:56 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if im not mistaken that will only make on ef the fans run
Old Mar 11, 2002 | 11:57 PM
Omar's Avatar
On my 89, my fan relays (I have dual fans) are near the battery. It may or may not be the same location in 88. Do a search.
If you have one fan, you ground one relay.
If you have 2 fans, you ground two relays.
Old Mar 12, 2002 | 01:12 AM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I have the exact opposite problem. My fan already runs constantly, and I want it to run only when the fan switch activates it. All the wiring appears to be stock (no splices or grounds). Anyone know how I can stop this?
Old Mar 12, 2002 | 07:56 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Which fan is always running? I'm guessing its the auxiliary cooling fan unless you have a bad ecm or a bad cts. If it is the auxiliary fan, you either have a)a shorted a/c high pressure swith and/or a shorted coolant temperature switch or b)you have a loose wire somewhere down the line that is grounding the relay. An easy way to test it is to (with the ignition ON but the engine cold and off) is to disconnect those two switches one by one (the a/c switch is on one of the lines going to the condenser, the coolant temp switch is located in the passenger side head) and see if it turns off the fan. If it does, that sensor you disconnected is shorted and needs to be replaced. If you disconnect both and the fan still runs, something else is grounding the relay and you should starting looking for exposed or loose wires..
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
jklein337
Sep 19, 2018 06:23 PM
lakeffect2
Aug 23, 2015 08:44 AM
jbd1969
Aug 17, 2015 07:06 PM
ZsTransAm
Aug 11, 2015 07:30 PM
