header bolt question
Old Mar 14, 2002 | 04:19 PM
breathment's Avatar
Iv tried asking this in the exhaust forum many times before with NO luck, so thats why i am posting this here...
im am installing SLP headers. how many of what sized bolts do I need?????? just for the headers going into the heads...... PLEASE HELP ME
Old Mar 14, 2002 | 04:31 PM
BTS88IROC's Avatar
generally its 6 on each side, that makes 12 total
Old Mar 14, 2002 | 05:48 PM
breathment's Avatar
thats the only thing i DO know............
What grade should i get?
Old Mar 14, 2002 | 06:24 PM
rezinn's Avatar
Order an arp grade 8 bolt kit from summit or jegs. That's what I'm using and they work great, good quality and easy to put together.
Old Mar 14, 2002 | 06:49 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Get the Stage 8 locking header bolts....you'll thank me for it later.
Old Mar 14, 2002 | 06:50 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Do your self a favor and spend the extra money on some stage 8 locking bolts. I can't get the locks on mine, but the hex head in the middle of the bolt helps in tight spaces.
Most bolts that go into the head will be generally a 3/8- 16 coarse thread. Don't quote me though.
Some of the bolts will have to be longer, get them from home depot or somewhere close and get grade 8 bolts.
Old Mar 14, 2002 | 07:04 PM
breathment's Avatar
can i just use regular bolts with lock washers? thats what the guys at speedtek told me to do since he said locking bolts were a pain to install. or maybe use some thread lock?
Old Mar 14, 2002 | 07:08 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I had the Stage 8s on my 1 5/8 SLP's. They SUCKED. No way I could get them tight enough with a crappy allen head wrench. Forget about getting a wrench (7/16 I think) around them to tighten with the way the SLP headers are made. I eventually bought the SLP bolts and pulled the headers, got the grinder out and "clearanced" the header flange to allow a 3/8" wrench on the SLP bolts. Now I can get them nice and tight. Don't waste the money on the Stage 8's You can't lock em down with the SLPs.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
