Maf
Old Mar 21, 2002 | 12:56 AM
orod's Avatar
Car: 86 Z-28
Maf
Biggest problems anyone has encountered by a bad MAF?
Old Mar 21, 2002 | 04:31 AM
ede's Avatar
ede
engine don't run right
Old Mar 21, 2002 | 05:48 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Hard starting, rough idle usually throws a code or two. Do not rule out the relays, usually have two for MAF. Power and burnoff relays. With engine running tap the relays with the handle of a screwdriver. If engine idle changes suspect them. Don't mess around, replace them both if they are original. Dealer cost is less than 40 bucks. If relays are OK you can use the same procedure for the sensor itself. Tap the unit and see if there is reaction. Don't rule out a dirty plug either. Get a can of contact cleaner and spray the connections. LOL, Danno 89rock, 5.7
Old Mar 21, 2002 | 09:22 AM
Vader's Avatar
Orod,
Whay do you ask? Is there something you're not telling us?
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
