Charging Problem
Old Mar 23, 2002 | 04:58 PM
89droptop's Avatar
Charging Problem
HEY I AM HAVING PROBLEMS WITH MY CHARGING SYSTEM. MY ALTERNATOR, BATTERY IS ALSO GOOD. ANY IDEAS. ON THE TOP OF THE ALTERNATOR THERE IS TWO WIRES A RED ONE AND A BROWN AND WHITE ON. THE RED ONE GOES TO THE STARTER AND THE BROWN AND WHITE ONE GOES WHERE?????? ANY IDEAS OR SUGGESTIONS WOULD BE GREAT. THANKS RICHARD
MY EMAIL ADDRESS IS RICHARDAWHITE@HOTMAIL.COM
Old Mar 23, 2002 | 05:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How do you know you have a charging problem? How do you know that both the alternator and battery are good?
Does your Alternator (maybe still labelled "Choke", don't know if it still was in your year) light on your dash come on when you turn the key to "on" with the engine not running?
Old Mar 23, 2002 | 05:33 PM
89droptop's Avatar
i had the battery tested and the alternator tested after i bought it. No i dont get any lights on the dash. I have had the charging system tested at autozone and the alternator is not putting out any voltage. The meter was reading the battery voltage. Thanks for any help. Richard
Old Mar 23, 2002 | 05:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Replace the light bulb. Without it, the alternator will never "know" that the key is on - the little trickle of battery that starts it up comes through the bulb, so if the bulb is bad, the alternator never starts.
Old Mar 23, 2002 | 06:01 PM
89droptop's Avatar
i do not have a choke light i have a check engine light and i believe that comes on when i start the car and goes off when it starts. I will look in the morning, i have the dash apart right now cause i am wire chasing trying to find where the third wire goes. Thanks
Old Mar 23, 2002 | 07:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You should have a choke light, it may not be visible without a bulb, I had an upshift light that I never knew about until I was cleaning the dash one day. Is the alternator squeeling or anything, or is just the gauge inside the car reading low, they're known not to be that accurate. Have you replaced the belt to the alternator recently, is it totally tight?
Old Mar 24, 2002 | 09:47 AM
89droptop's Avatar
yes i have done all of the dummy checks and i have the dash apart and i do not have a choke light. thanks again.
Old Mar 24, 2002 | 08:11 PM
89droptop's Avatar
hey dont worry i found what it was. The reference voltage comes off of the same fuse as the electric fan. So thanks for the help.
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
