Real Quick Simple Advice
Old Mar 28, 2002 | 10:31 PM
primer84z's Avatar
Can anyone tell me how to get my dipstick tube out? is there a bolt or something that holds it down in there? Also how would i go about checking to see if my oil pressure sender is leaking oil? Thanks guys.
Old Mar 30, 2002 | 01:22 AM
Vader's Avatar
Primer,
The dipstick tube is generally swaged on teh end that is inseted into the case, and is just pressed into place with an adhesive/sealant in the gaps. You usually have to get a little heat on the tube and grip it with pliers to get it to break free, then it can be pulled out.
As for the oil pressure sender, just clean it off thoroughly and monitor it for a few days. Leaks should be pretty apparent.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
mrdevontay
Sep 2, 2015 08:04 PM
