Standard length pushrods?
I am installing some comp cam roller rockers and am going to go on and put some new pushrods in while I'm at it... I figured I would go with the comp cam magnum pushrods... Jegs has some "standard length" is this what I need? Some other shops around here just sell them by different lengths... btw - the car is an '85 TA with stock L69
thanks
thanks
I believe you need 5/16" diameter and about 7.79" long pushrods. You should look for an application chart or something, though. "Standard length" should be correct if it says small block chevrolet pre 87 or flat tappet.
gixxer92
May 18, 2017 11:20 AM
Gunner242
Dec 25, 2015 04:49 PM
