car died
Old Apr 3, 2002 | 02:04 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
car died
While I was comming back from lunch today my car just died. It won't restart- it just keeps cranking -the tach is not moving and I have no spark, the hand held controler shows 0 rpm's so it's not firing the injectors. I checked all the wiring and they are all good and I have no blown fuses, by the way this is a edelbrock 1000 cfm EFI setup and I have had no problems other than this one. I already replaced the coil since this happen so the coil is not the problem, I am leaning tward the ignition control box because the computer is not getting a signal, any other ideas?, when I get back from work tommorow I am going to call edelbrock tech support and see what they say.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
