PIC...anybody ever use this?
Old Apr 9, 2002 | 09:52 PM
IROCZ88's Avatar
It's called an electrolytic coating or something like that and you apply it to your lifter valley. A couple people recommended this to me so I tried it. I haven't had the intake off since it's been running so I don't know how its holding up. Nothing in my oil or oil filter though so it must be allright.
Old Apr 9, 2002 | 10:37 PM
Vader's Avatar
It's called General Electric Glyptal enamel. It is a high dielectric insulating paint. It seals porosity well, which is one of the byproducts of its insulating capabilities. As of about two years ago, it was still available. It used to be the hot ticket for painting engines internally,
Old Apr 10, 2002 | 03:46 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I believe that people paint the lifter valleys to aid in oil drainback. I don't know if it helps or not but it probably coundn't hurt. and it does look good .
Old Apr 10, 2002 | 05:11 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Vader
I'm pretty sure Glyptal is still available. Doesn't Eastwood sell it? What benifits would you even get from using it, especially in a street driven car?
Old Apr 10, 2002 | 05:26 PM
GreenProStreet's Avatar
[QUOTE]Originally posted by grafx
Vader
[/QUOTE
That is what I would like to know! Is it just for the oil drainback effect or does the insulation of the lifter valley not transfer heat to the intake manifold?
Old Apr 10, 2002 | 05:36 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Glyptal's been used for years by engine builders.
Still Available from Eastwood.Brush-On Quart is $24.99 Item #46001 ZP at:
www.eastwoodco.com
Also POR-15 Engine Enamel works well and is available in several colors.
www.por15.com
I've had good results with both.
-Rich-
Old Apr 10, 2002 | 05:45 PM
IROCZ88's Avatar
Thanks Vader, I knew I didn't get the name right. I was told It helps keep heat in the combustion chamber so not as much transfers to the intake by a local sprint car engine builder..
I think it helps with drainback too. I smoothed out the entire lifter valley with a die grinder so it looks and feels real good. It got rid of a lot of stock casting flash.
