My brother's ride vs my formula 350
Car: 88 Formula 350
Engine: 357
Transmission: 700r4 Edge 2900 Stall
I'm guessing that unless I use nitrous my brother's gonna smoke me!?! Just goes to show you.......well I'm sure it goes to show you something!!!!
He lives in Eugene, Oregon and I live in Chico, California so I doubt he's gonna drive down here and give it a go....and I'm certainly not driving up there the way the price of gas has gone up.
MY BROTHER"S RIDE:
His car is so clean you could eat off any part of it......he said he get's a kick out of checking the oil at the gas station and having dudes walk by with their tongues hanging out. He hasn't run it down the 1/4 mi. YET.....keeps saying "it's a sports car........".
Well at least I'm not too worried about a shopping cart rolling into mine...... . And you can't beat the sound of a 350 on Flowmasters......
MY BROTHER"S RIDE:
Car: 88 Formula 350
Engine: 357
Well I believe it's all powdercoated actually.
I'll get him to send me a list of his mods.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
first want to say I find this funny that since newbie has had his problem with me saying all I do is rant and rave about how good imports are and how they are so much better then thirdgens and I'm just a r<x>icer and and that he is happy his fairly modded car can beat my 16 second car or can woop my other car which has a whole 68hp and such all the rx7 threads have been comming about.
but as far as I can tell who knows who will win
don't know much about the car him stock vs you prolly you taking the win being it looks like you have quite a bit more done then just a sotck 350
but all I can assume on the car is the year is a 93 and I'm guessing the R1 package. other then that *shrug* looks like he can have quite a bit of looks good parts but not much for performance or he could have quite a bit of go fast goodies. so I give him anywhere from mid 14's to mid 11's
Car: 88 Formula 350
Engine: 357
OK..I went to his VBgarage and got his mods:
Engine & Exhaust:
Gotham Racing SS DP & High-Flow Cat
Racing Beat Dual Tip CB
AWR Competition Radiator
Apex Dual Intake
RX-7 Store Intake Pipes
Efini Y-pipe
Greddy SMIC
Greddy Elbow & Intercooler Pipe Kit
Polished UIM & Alternator
Alum ASI AST
Silicone Hoses
Samco Radiator Hoses
New Water Pump
Replaced All Remaining Coolant Hoses with New OEM Parts
Magnecor 8.5mm Plug Wires
Greddy Pulley Kit
Airpump & AWS Removed
Turbojeff Battery Tray
Optima 51R Yellow Top Battery
Fuel Pump / Management:
Apexi PFC w/Commander
Walbro 255LHP Fuel Pump
Suspenision, Wheels & Tires:
Black R1 Strut Bar
Brembo Cross Drilled and Slotted Rotors F&R
Goodridge SS Brakelines
Hawk HPS Pads
Eibach ProKit Springs
Tokico Illumina 5-Way Adj. Shocks
RB Front & Rear Sway Bars
RB Front Reinforced Sway Bar Mount
AWR Reinforced Sway Bar Mounts
99 Spec Rims (F17x8, R17x8.5)
Yokohama EVS ES100 (F: 235/45-17, R:255/40-17)
Oh yeah...twin turbo...yada, yada......
Engine & Exhaust:
Apex Dual Intake
Efini Y-pipe
Greddy SMIC
Alum ASI AST
Silicone Hoses
New Water Pump
Greddy Pulley Kit
Black R1 Strut Bar
Hawk HPS Pads
Car: 88 Formula 350
Engine: 357
Well I guess I hafta figure that out..don't I?
I need to get this chip burning thing figured out and maybe then I'd be in a better position to say.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
Man, get a good solid tune on that car, some 3.73's and you should knock out mid-low 12's and on DR's hit high 11's. Thats an awesome setup but it HAS to be tuned right. On my Edelbrock setup, I liek it because you plug it into your laptop and record everything you do while driving, then itll basically help you tune for the optimum settings. we put it on a 305 and it was a little too much for it but it ran and purredl ike none other and the dash mounted control box was helpful without a laptop but when you had the laptop on it, it was awesome tuning it.
Goodl uck and get that bad ride tuned!
Car: 2005 BMW 545i
Engine: 4.4L N62B44
in his current tune as long as he is running stock boost give him about a mid to high 13 if he can drive it right.
I admit I don't know much about the thirdgens (rx7) and how well they perform with exhuast mods but I know on a second gen they can do quite a bit but still most can't launch a rx7 right
but I agree with the others here after going back through your mods and so forth get that thing tuned....
He can't make much more power without after market fuel management which it doesn't look like he has. In fact, I think he won't be able to go much over 12 psi if I remember correctly. So, judging from what the more knowledgable members said about your car, looks like you've got this one just fine.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
good point forgot about that one stu
but I would still think he should be able to get a little faster
but as far as 12 psi
could have sworn the stock injectors... well on second thought I scratch that the stock injectors sucked and already where mostly maxed out
so if he was able to get some better injectors he might be able to do a little better even using the stock system (though no recomended)
but either you way you have a healthy combo and if you can launch you can beat him
just don't even come close to expecting to take him in the twisties.... if you do that give your brother a flat tire first and make sure he sees it before the race. you win by default
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ok now I feel like a tard
I read the walboro pump thing many many many times and even after you posted about the apexi power fc I still missed that part a few times
but without fuel upgrades I would won'der how much he really can get out of htat car. bigger injectors would be a nice plus
but at least this guy is on the right start with the later year rx7
get rid of the factory crap like the radiator, ecu, intercooler and replace with much better good stuff
gotta love the days mazda goes cheap and just about ruins a good car
Car: 1985 Trans Am
Re: My brother's ride vs my formula 350
You seem to know a lot about cars so if you dont mind I need some good advice. I have a 85 transam tpi that originally came with the 305 and I just recently dropped a brand new crate 87 firebird 350 in it. It drives good except for getn up to 220-235 degrees when I ride on street for more than 10 min and I dont feel like Im getn the torque and power I should be getin from it even when its cold on the highway.Is there anything I need to and can change from the original 305 parts. I heard I need to change my injectors from the stock 305 injectors to some 350 injectors, is this true. I have a 185 degree thermostat in there instead of the stock 195, a brand new radiatior, im not loosing coolant,and i just got the system flushed. Do you think the water pump is to blame? Please help me out as one Firebird lover to the next, I dont know how to veiw your response bein that im new to this site so if you could email me cainestl@yahoo.com I would highly appreciate it.
thanks,
Caine
thanks,
Caine
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Bump From the dead. Firebird is mine now. Running alot better. And his engine has changed. Twin Turbo engine Blew, so now He is putting in a brand new Ls2. And for cainestl, I would try a new Thermostat.
-Gaspar
I have a 85 transam tpi that originally came with the 305 and I just recently dropped a brand new crate 87 firebird 350 in it....
-Gaspar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
thanks,
Caine
thanks,
Caine
honestly you prolly need to get a new thermo and unrestict the plenum and runners and if you didnt do it already you may need to replace your fuel pump with a bigger lph/gph
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
i love FD's... but i hope he doesn't overheat.lol. but from a dig i think you got him but i think anytime from a roll he has you.
btw did he repaint his car? i never seen a Twin turbo come in silver.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ALL rx7's from 93-95 came twin turbo. auto, stick or any color you wanted it was going to be twin turbo.
ealier years it is another story.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I am sure he wont overheat, as i said in the previous thread, he blew it up going to a car show. So he bought a brand new Ls2.
i thought they were either twin turbo or na.... guess i was wrong.
Car: 2005 BMW 545i
Engine: 4.4L N62B44
in the US from 87-91 they could be either or (but turbo was only single), from 79-86 they where all N/A and from 93-95 all where twin turbo. so in a way you are partially right
thier we go.lol seee you teach me on Rx7's and i will do the same for you with honda... even tho i should kill you beacuse your avatar.lol
Car: 1985 Trans Am
Hey thanks for the advice. The overheating thing with the bubbles definitely worked. I had alot of air left in my system. Now shes as cool as eskimo punani. Do you know where i can get a high performance ecm and prom chip to benefit my 350s performance. I heard i can get the prom chip off a 85 corvette with a 350 is that true. Anyway thanks for all your help bro.
Caine
Caine
Car: 1987 Firebird
Caine, this is very common when switching something, and/or exposing the coolant system to allow air entry. With then engine cold, pull the radiator cap off, and start the car. Don't worry, the coolant will not spew out. Once the car is started, turn your heater controls ON, and let the engine idle for approximately 5-10 minutes. Your going to need to get some additional antifreeze coolant, as you will be adding it to your radiator until the system is adequately full. When no more bubbles are prevalent in your coolant (through careful observation), put the radiator cap back on, and your good to go. If the problem persists, do the very process again. If it still persists, you might just have yourself a sticky thermostat....
-Gaspar
-Gaspar
you know how many dakotas and durango's i have done that too pretty bad that they decided to design the fan should and tanks like they did.
Car: 88 Formula 350
Engine: 357
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Wow...yeah, better get working on it! That thing is...niice. I want an LSx motor...but too much money.
