4.6L mustang and third gen
1 Post
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Alright so he has a 4.6L mustang with
Full bolt ons from intake to exhaust
trick flow heads
mild cam
stock drivetrain (5 sp)
street tires
I have:
388 fully forged
comp cams XE284
holley 700
3" cat-back with gutted cat
3.42 posi rear on sticky street tires
T-5 (might have the 700r4 in by then but doubtful)
port and polished heads with 2.02/1.5 valves
My heads are holding me back the worst...But who will win? Im thinking the stang but he cant really drive.
trick flow heads
mild cam
street tires
I have:
388 fully forged
comp cams XE284
Duration: 284/296
Lift: .507/.510
LCA: 110
Cam advanced 1*
weiand stealth intakeLift: .507/.510
LCA: 110
Cam advanced 1*
holley 700
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: 4.6L mustang and third gen
sounds like a good race. Unfortunately I don't have any info on the outcome. Maybe 25thmustang might chime in...
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Trick Flow heads I believe just came out for the 4.6 cars... What year 4.6 car, what cams? More info is needed for me to he an idea.
1 Post
Car: 86' IROC
Engine: 388
ok i found out he has stock heads but rear gears 4.11. He wont let me know much about the cam. short duration but .5xx lift that is all he would tell me.
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
What year is the car? A bolt on, cammed 4.6 "could" be an 11 second car on a set of tires. It could also be a 14 second car!
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
A reference pic of a similar mustang could help us.
If it's a soft edge, you have to find a year since 94-95 were 5.0s and 96-98 were the 4.6.
I dont know who would win but I have been a Ford Man since birth ( i bleed blue). I have a 97 mustang Gt with an Aluminator block, patriot stage 3 heads, and a Street racer cam with .500 lift,high nickel forged pistons and crank, a Tremec TKO 600, Aluminum Driveshaft, and 4.10 Posi gears. its estimated @ the crank to be around 450 hp. but i dont know if his is that built but id bet on the mustang. these 4.6L engines can rev to 6000 RPM in stock form and build HP all the way to the limit. So all in all i would bet on the stang in my experience if i was the stang driver. ive beat LS1s. but if hes BS'ing id vote u. i dont know if that helps or not
1 Post
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Beat an LS1 in stock form? () Or beat it with those mods? Cause why even bother saying you beat an LS1 with 450hp... Of course you'll beat an lS1 with 450hp. lol
1 Post
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Engine: gone
Transmission: gone
Axle/Gears: gone
being that ppl bs about thier car i bet his car does at best a high 13. i have no idea what your care does..im leaning towards the stang winning..unfortunately..
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
id dont see y a 388 with that cam cant be breakin 12's ive got less cam and when i get the new tranny in ill be there.
whats so crappy bout your heads yea your exhaust valve is a little small but thats not a big deal.
1 Post
Car: 86' IROC
Engine: 388
Ok for an update, I now have a built 700r4 with 2400 stall (came with the tranny) and I should have 3.42's out back with a spool and drag radials.
now who might win?
o did i mention he will be on a old set of crappy directionals.
I'm hoping with a 3300 stall this summer I will hit high 11's
Thanks,
Chas
Engine: 383
ive got my money on the thirdgen. a stroker motor makes a **** pot of torque. and i hate to say it but no single overhead cam 4.6 made power even with bolt ons they seam to be dogs. now if he went to 32 valve heads that would be a completely different story.
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I'm thinking you got him.... Just a guess tho
And this post is hella old
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
most modded mustangs are only good for making noise and they need some sort of power adder to get any faster extremely rare that someone has a fast one with just bolt ons theres a high chance hes just another noise maker. but who knows.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I doubt you will be running a high 11.... That is quite a time slip with slightly modded heads.
1 Post
Car: 86' IROC
Engine: 388
the heads are 2.02/1.50 they aren't slightly modded..they have quite a bit of work. i have seen a lot faster camaros with a lot less done. I will keep this thread on the back burner till the snow is gone...
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
The 1996-98 pre-PI 4.6s are total dogs. Maybe 180rwhp in stock trim... Even with optimized full intake/exhaust and better cams, he'll be at around 230-240rwhp. I don't see how you lose this race...
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
My 96 ws6 stock would tear sn-95 stangs apart, and was neck and neck with a vortech super charged 97 gt. It would be better if it was a 5.0 since I have had 2 foxes and they were fun and quick. Early mod motors suck without aftermarket or pi heads and some good money invested and gear and exhaust and slicks and turbo and a blower and nitrous and a diesel motor and gods hand......
Well, just race him & see who wins! I've beaten a couple of Mustangs in my IROC-Z. I'm not afraid of a Mustang & neither should you be! Haha, just enjoy the race & try to make a video if you can.
Find one & see how it turns out. Or do what I do. Let one find you, then get up next to him & freaking hit the gas pedal. Make sure not to hit anybody in the process!
I think it's funny when a Mustang drives behind my car to the left or right side slow enough that you notice them. I've had several Mustangs do that to me. My best guess is that they're trying to figure out which car I have because there aren't alot of true 350 IROC's out here.
I think the third gen has the 4.6 if its that old crappy 97 defiantly my buddy has a 94 5.0 GT with a crap load of bolt ons and my friends 94 z would eat that thing alive every time and it only had a damn flowmaster on the car and the rest was stock. Im waiting to finish my car to take a run with my friends 5.0 rustang
Car: 1988 Formula
Engine: 388ci
Transmission: WC T-5: t56 in the makes
Axle/Gears: 4th gen rear 3.42
i dont see how the mustang could get this third gen, mine has shitty exhaust and it laughs at 4.6 mustangs, unless you just spin through the first three gears, i'd say you got him. famous words "there's no replacement for displacement."
Car: Escort GT
Engine: 1.8
Transmission: Stick
Axle/Gears: Both
A 97 gt? there is a brutal 15 sec car right there...you better watch out...lol
1 Post
Car: 86' IROC
Engine: 388
His car might be a little faster now...
Here is a list of upgrades he did.
Intake
cams
heads
exhaust (full)
gears
bottom end untouched
Its a fuel injected car with 2v heads, i have no idea on the power he could make with these mods.
His last car he dumped 8k into a 5.0 fox body and the best he could get out of it was 13.6 (5 speed)
This car is also a 5 speed and he can't drive.
EDIT: I was just looking on summit and the trick flow top end kits is only rated for 390hp/375tq. I should have about 450hp/450tq (at least) so I still don't think i have anything to worry about with my car running the exhaust uncorked and being auto.
Intake
cams
heads
exhaust (full)
gears
Car: 86 iroc-z
Engine: 305 tpi
daaamn thats fast, i know a guy whos goin to the track and i thought we might be close but i guess not, wish i could afford a bigger engine.
1 Post
Car: 86' IROC
Engine: 388
EDIT: Doing a little research told me they didn't make the mach 1's until 2003-2004 and were a limited build. basically the same motor as the SVT Cobra but without the badges.
Engine: 383
its the non supercharged cobra motor so like an 01 or so with a solid rear end.
Intake
cams
heads
exhaust (full)
gears
Intake
cams
heads
exhaust (full)
gears
i'd have to go with the iroc. i've seen a 350 sbc in a 87 camaro beat a procharged o4 gt. i doubt that 4.6 is close to that. one of my friends put full exhaust and intake on his 96 gt. he got it dyno tuned and put down a whopping 208 to the ground! hahaha! i doubt you'll have any problems.
in fact. here's a vid of my friend in the 87 camaro hanging neck and neck with an 03 pullied cobra.
http://www.youtube.com/watch?v=aYazpBfpOco
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
dayum... on the 3rd gen is that all cam?
#42
what do you mean all cam?? he was supposed to be spraying but the wide open throttle switch got knocked loose. his cam wasn't that big, he just had a really tight lsa. i think it was around a 108 or 109. thats what made it sound so choppy.
#43
1 Post
Car: 86' IROC
Engine: 388
New2Chevy
09-28-2015 12:35 AM
