Hypothetical ThirdGen COPO - Third Generation F-Body Message Boards
Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Thread Tools Search this Thread
Old 01-07-2018, 02:14 PM   #1
Speed Racer's Avatar
Car: '87 Camaro Sport Coupe
Engine: 383
Axle/Gears: Ford 9, Detroit Locker, 35 sp, 4.11
The idea of the 1st, 5th and 6th gen COPOs is fascinating. So, that makes me wonder... what if they made a 3rd gen COPO? What engine would they use? What would the suspension be like?
The ZZZ 350 engine came out in '89 and had 345 hp. I bet they would have used that combined with an old school TH350 trans with a bit of a stall. They might have probably used the Dana 44 rear end since they did make some for this car already. A Ford 9" might have been overkill for this simple small block. The real questions is the suspension. They probably would have just went with a beefed up stock-type system rather than custom fab 4 link. I think they would have just kept it simple back then.
So, what are your thoughts?
(note: I'm not trying to start an argument as to whether 3rd gen COPOs existed... despite what your brother's dog's cousin's uncle says.... they didn't exist)
Speed Racer is offline   Reply With Quote
Old 01-07-2018, 02:30 PM   #2
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: Hypothetical ThirdGen COPO
1LE in 88 was Close to this, if you knew which boxes to check
Big&BadGTA is offline   Reply With Quote
Old 01-07-2018, 06:26 PM   #3
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Most of the original performance COPOs (I think any fleet order like police cars were COPO also but not considered here of course) was just ordering an engine that was larger that was normally available but was still available in other platforms, such as Corvette, and agressive gearing on a mid level model. The 425HP 427 was the engine for COPOs in '69 with a few very special aluminum block versions. A COPO Chevelle I know would have been a Malibu (not on the SS) with a 4 speed and 4.10s.
So, it might simply mean an L98 with alum block (if there was an aluminum race version made) and heads and 4.10 gears - but following suit it may have not been available on a Z28/IROC. An RS perhaps.
Bow_Tied is offline   Reply With Quote
Old 01-08-2018, 03:24 PM   #4
Engine: 383
I agree that it would have definitely been a base RS car. But it would be horribly disappointing it would have been anything like a barely-different-than-stock 1LE or had an L98- even it was all aluminum. Then again, it was the 80s, and GM liked to make stuff like they hated it.
I see that the high compression LS7 454 was still available in the 80s as a crate engine. They might have put that in there with those terrible Hooker Super Comp headers. I know they did build some 454 test cars in the early 90s, so they might not be opposed to this idea. If going with the big block, they might have done a tricked out Powerglide and a Ford 9. That would have been sweet.
Old 01-10-2018, 03:48 PM   #5
Abubaca's Avatar
Car: 1989 Iroc
Engine: 383 TPI
Transmission: TKO600
Gotta remember that in the 60's, the COPO wans't a brand, it was just an acronym for the description of how you ordered these vehicles. It didn't SAY anywhere that it was a COPO car. Similar to (but not exactly) how the Z28, Z06, Z71 have all become brands, with badging, etc. etc. At one time they were just a set of letters and numbers no different N64 spare tire. No one says they have a Camaro N64. It's interesting to read about them because short of what they were and how many were ordered, there's not really a lot of info. No COPO literature, no brochures, no commercials, and back then you didn't say I have a COPO. Heck, most were boring fleet cars and taxis. It wasn't 'til later on that it really became a thing.
...but nowadays, COPO IS brand, no different than Z28. -and a performance brand to boot. Funny thing is that the Z28 still has that z 2 8 RPO, but I highly doubt a COPO requires a central office production order
And I'm also not sure how you could've circumvented the EPA during the 80s. Back in the 60s you could just stick a ZL1 in a Camaro if ya knew to use the COPO. Nowadays you couldn't do that, even if Chevrolet would let you.
So yeah....basically 1LE. No reason that I can see that it couldn't have been an Iroc. -or any other trim. Powertrain options would still have to have been something we're all aware of like a LB9/t5 etc. etc., otherwise the EPA would've stepped in. COPO worked around GM rules, but didn't have to deal with the EPA.
I know. I'm a party pooper.
Abubaca is offline   Reply With Quote
Old 01-10-2018, 05:01 PM   #6
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
They built a couple of those and had them out at the Mesa Proving Grounds. Bad *** cars for sure!
PurelyPMD is online now   Reply With Quote
Old 01-10-2018, 05:42 PM   #7
Engine: 383
Quote:
wow! man, they should've sold 'em!
Old 01-11-2018, 09:25 AM   #8
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
IIRC, COPO
Central
Office
Production
Order
TTOP350 is online now   Reply With Quote
Old 01-11-2018, 03:25 PM   #9
Car: 1983 G20 Chevy
Transmission: 4L60
The TH350 was way out of production by that point. The TH400 was still being produced for trucks and fits right into the tunnel. GM probably would have used the TH375 version with a short tail (vs 4L80E length long tail) and the TH350 sized output shaft. GM probably would have stayed with the Austrailian 9 bolt and 3.45 gears like the 5 spd G92 cars had. GM might have been able to tweak the ZZZ enough with a SLP T-Ram to get it pass emissions.
Fast355 is offline   Reply With Quote
Old 01-12-2018, 10:34 PM   #10
Car: 1992 RS/89 Formula
Engine: 305 TBI/350 TPI
Transmission: auto
Axle/Gears: 2.73/3.08
1LE is what your referring to, there is also the G92 package. Also, dont forget about the Firehawlk in the early to mid 90s. Second of all no police car has a special engine. Police cruisers are the same as the civilian models always, they only have heavy duty suspension and high out put alternators to run all the equipment.
Ibazzabar92 is offline   Reply With Quote
Old 01-13-2018, 09:47 AM   #11
Quote:
Not always limited to suspensions and alternators, as the exhaust configuration might be different or specific, seats, etc.
I had a 2007 CVPI which was equipped with "stab proof" seats, and were much more supportive, even in "admin" trim than a grandpa model. It also had a straight air inlet tube without sound baffling, no under hood sound deadner or intake manifold covering, and the alternator was clutched, for reliable service during upshifts. It also had silicone hoses and special hose clamps, etc. Pretty neat car. And different. One of the best vehicles I've ever owned!
But if we're talking about Camaro police package, still special, but not quite as much unique from other models which could have similar options.
Old 01-13-2018, 04:09 PM   #12
Car: 1983 G20 Chevy
Transmission: 4L60
The 9C1 caprice TBI engines had a police specific engine that used a L98 camshaft rather than the 305 TBI peanut cam, larger police specific injectors and police specific prom chip. The exhaust was revised and the valve body and governor in the 700r4 was built to allow a WOT 3-4 upshift.
The 9C1 LT1s also had some goodies aside from the normal civilian models. The had revised tuning, silicone hoses, and other tweaks for better service life in grueling conditions.
The GMT400 Z52 Tahoes were also substantially different from production models. They had an add on electric cooling fan, revised programing and a 3.08 rear axle as well as programming that allowed the 4L60E to shift into OD at WOT.
In the pre-emissions days cars like the Ford Galaxie with the 390 V8 had hotter camshafts that were often solid lifters to get more RPM and HP from the engine. Some of the older interceptors also had dual 4bbl carbs or 3-2 barrels from the factory.
Old 01-14-2018, 10:01 AM   #13
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Right, I think there was a 352 version, thunderbird interceptor, or something like that. I recall looking at a '58 claiming this. My dad has a '59 Galaxie 500 but just a standard 352. Neat cars.
Not sure what you mean, I understood 1LE and G92 to be an RPO code, and not a model or ordering department. Or do you mean that 1LE is a modern COPO equivalent? Perhaps, but performance COPOs in '69 had engines of larger displacement than was normally available... there may not be a modern equivalent for 3rd gens in this case short of a truck engine. In '69 there was a corporate limit of 400CI or less in an intermediate car and the COPOs were the work-around to this rule.
This could be also interesting to discuss what would have a 3rd gen looked like with a Yenko or Baldwin Motion work over which there the Firehawk I think is a prime example.
Old 01-14-2018, 10:16 AM   #14
But Firehawk was an RPO, too...RPO B4U, 1991-92
Dealer conversions, while possibly neat, don't mean the same, or close.
Old 01-14-2018, 10:36 AM   #15
Car: '90 GTA Trans Am
Engine: 305 w/T76 Turbo
Transmission: Stalled 700R4
I remember GM building both a 454 C4 and 3rd Gen Camaro back in the day, one named Big Doggie and the other Angry Poodle, you can obviously guess which one was which being that the Corvette platform was always their flagship. The Camaro actually ran a carburetor while the Vette was given a modified tunnel ram running EFI, which is where the idea for the Holley Stealth Ram essentially and eventually sprung from. I have the article detailing the Angry Poodle Camaro if anyone is interested in reading about it, it was a Red RS Camaro, I believe it had Gray ground effects if I remember correctly. It was about a half a second slower than the Corvette which was clocked at 13.00 ET, the Camaro running a 13.50, which for the early 90's was very quick.
I don't recall the trap speed off hand...
- Rob
Street Lethal is offline   Reply With Quote
Old 01-14-2018, 10:56 AM   #16
Car: 88 Trans am
Axle/Gears: C4 IRS 3.42
I thought that GM built big block Camaro was called "Great white"
88Greg is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
87 Camaro Sport Coupe, COPO clone?? Opher History / Originality 34 09-09-2012 11:21 AM
1989 IROC-Z28 COPO Camaro??? CAMARO&TA GUY History / Originality 10 03-05-2009 04:37 PM
COPO 427 CUBIC INCH BIG BLOCK snapsmagee2000 Engine Swap 40 06-24-2006 05:19 PM
Any info on this 91 COPO? JimmyG-91Z History / Originality 8 12-20-2002 10:06 AM
Can I tell a COPO by the VIN? Aaron91RS Tech / General Engine 10 11-05-2001 08:10 PM
Go Back   Third Generation F-Body Message Boards >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
1982 Camaro '82 || 1983 Camaro '83 || 1984 Camaro '84 || 1985 Camaro '85 || 1986 Camaro '86 || 1987 Camaro '87 || 1988 Camaro '88 || 1989 Camaro '89 || 1990 Camaro '90 || 1991 Camaro '91 || 1992 Camaro '92
All content copyright © 1997 - 2018 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
