looking for underdrive pulley set...or other mods
Im looking for an underdrive pulley set for my 1987 Trans-am ..Any suggestions, Can you really tell increase in HP..Ive got a little work like flowmater, straight pipe, 160 stat, KN.,..im going to port plenum and runners too...
How much and where to buy and how much gain?
ALSO any other mods for my car that would help it out
THanks
AJ
Looking for a rear end also
aj
THanks
AJ
aj
Dont waste your money on the pullies. Get yourself a set of Flowtech or Headdmen headders. Cheap and easy, just the way I like it.
$200 bucks total. Best bang for the buck mod I've done yet.
Later Barrett
$200 bucks total. Best bang for the buck mod I've done yet.Later Barrett
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
IMO every bit counts. If you are willing to spend the money buy the March Power and Amp 3-piece set. They will give you 11 HP (aprox) and look pretty good too. If you use the March Performance set which has a larger than stock alternator pulley, the alternator will not turn fast enough and you'll get on the red on the gauge.
http://www.marchperf.com/pg1.html
I have a set in my GTA and I'm very satisfied with it. For price you'll have to call around.
Ozzy
Ozzy
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
SOP feel was a little gain but i also did the k&n at the same itme so im not sure
but i agree with wataru get some flowtechs gut your cat and get a flowmaster and you will pick up gobes of pawer and also get rid of your smog
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Agreed, you will get more gain from a set of headers, but get them ceramic coated and save yourself some grief.
You'll get some HP from underdrive pulley(s) and a little quicker rev. Consider that most are 20% underdrive and how much HP is used to spin the accessories. If you normalize trap speeds for weather you will see a slight increase but the SOTP won't feel it. Summit sells March sets; March makes a very nice product.
I run March underdrive on the IROC and on the Vette; indeed, every little bit adds up.
I liked my march pullies, the gains I realized are in my sig. Just get the 2 piece set, the ALT. pulley is actually smaller to speed it up more. If you get the 3 piece set, the water pump pulley will be smaller also to speed it up.
Headers will also help.
nick
nick
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Unless you changed the pullies at the track the same day & ran back to back runs. Your increase could be very well due to some other factor such temp, humidity, barometic pressure, wind, etc.
bigjay89gta
Oct 15, 2015 08:04 AM
