need some help, have ?s inside
Old Jul 27, 2002 | 04:21 PM
fastz28's Avatar
hey all, I am trying to help a friend get his 90 TA running right
350 TPI, large cam, aftermarket heads, bbk tb, stock intake, k&n off the tb, accel 300 box and coil, shorty headers and flowmaster exhaust, too large (imo) 32# accel injectors, small torque converter, 3.23s
firstly I thought 90s were mass air?
the car loads up, won't rev past 4500 and is just an all around dog
no I don't have the actually cam specs and he's on vacation for 2 weeks
any ideas of where to start? (besides the tune up lol)
tps?
what's the usual fuel pressure?
anyone local in central IL wanna help a brother out?
please feel free to toss out ideas and thoughts/suggestions/advice on how/what to check or fix
thanks
Old Jul 27, 2002 | 04:23 PM
fastz28's Avatar
holy crap!
I registered in march of 2001 and that is my first post?!
Old Jul 27, 2002 | 06:28 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Here's a piece of advice that is going to save your freiend a lot of money.
Do not attempt to run that engine again until you burn a chip with the proper injector constant in it, or put the stock injectors back in
The reason it is (barely) running that way is because you are dumping nearly 50% extra fuel with those injectors. And when you dump that much extra fuel you will wash down the cylinder walls, causing excessive wear, and also contaminate the oil with raw fuel which will thin the oil and destroy the bearings.
The injector constant and injectors must match or you are gong to be completely off in your fueling. Even the poplular swap to 24lb SVO injectors is foolhardy and hamfisted if you don't adjust the PROM to accomodate the change.
Old Jul 27, 2002 | 10:28 PM
jd13's Avatar
Yeah basically what he ^^^ said.
And the cars produced later in 90 were speed density.
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
