what should i expect from l98 heads and intake on a 305
Old Aug 14, 2002 | 08:23 AM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I have an lo3 on my 89 rs and i got L98 heads and intake off of an 89 formula and i was wondering what i could get out of putting that on a 305. i was told that i could lose compresion some how is it true? How munch more horse power sould i expect form it? and how much faster would i be at the track with that set up? thanks for any help
Old Aug 16, 2002 | 06:13 PM
tpi_roc's Avatar
You'll lose close to half a point of compression, which will lower performance, you'll flow a little more, which should raise, all in all it will become a trade off probably just slightly more biased to a gain maybe.
If you're going to do it the only way I could think of making it worth it is to port the snot out of it and have it decked to recover some of the lost compression.
Old Aug 16, 2002 | 09:03 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
replace the cam as well, that's another weak point of the LO3
Jake_92RS
Jan 28, 2020 10:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
dutch930
Sep 11, 2015 06:58 AM
