Runners
Old Nov 20, 2002 | 01:18 PM
roadog115's Avatar
Car: 1992 Camaro Z28
Engine: L98 350 ci.
Transmission: 700-R4
Runners
I'm thinking of porting my intake and my plenum this winter. Would it be better to get bigger runners or should I just port the stock ones??
Old Nov 20, 2002 | 01:24 PM
383 rocket bird's Avatar
It all depends what kind of budget you are on. Porting the stock equipment will show you some gains but they will be minimal. The advantage here is that it is free. For greater performance go with aftermarkt runners and port your own plenum. This is more expensive but tends to yield better results. Also without knowing your mods it will be hard to determine what kind of gains you will get with these kinds of modifications. hope this helps
Old Nov 20, 2002 | 01:29 PM
roadog115's Avatar
Engine: L98 350 ci.
Thanks. I saw a pair of runners from Doug Rippie and the were over $500 so that's why I asked if the aftermarket ones were better. All I have on my car are Edelbrock TES headers and Flowmaster. What would be a good pair of runners to put on?
Old Nov 20, 2002 | 02:37 PM
Desert86Roc's Avatar
The SLP runners are around $300, but you can get them cheaper. They may not be the biggest right out of the box, however, since they are cast aluminum there is much more material to work with (porting), and you have the added bonus of being able to siamese them and shorten your runner length giving you a little more top end. I dont have any pictures of the porting I did, but I do have the finished installed result.
Old Nov 20, 2002 | 10:08 PM
MdFormula350's Avatar
thats one pretty engine Desert86Roc
slp runners are suppose to take some low end torque and give you more top end where needed..
Old Nov 20, 2002 | 10:17 PM
I usually don't post non tech related but Mike that engine is straight beautiful. All that polishing you did really makes for a beautiful engine.
Old Nov 21, 2002 | 03:17 AM
The Anvil's Avatar
Car: 1989 GTA
Engine: L98 350, dual cats
Transmission: 700R-4
Holee cow...
I have to chime in here also - thats one beautiful looking engine. I cant imagine the hours spent detailing and polishing - simply awesome.
Two-thumbs way up.
Dave
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
