Plug gap?? Quick one
Old Sep 9, 2003 | 08:30 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I have a 91Z 5.7 and under the hood it say's the plug gap should be 0.35, really my plug's were gapped at 0.45. Would that hurt performance much, and could it cause spark knock??
Old Sep 9, 2003 | 10:51 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
plugs can cause knock but not normally because of the gaps.
IMO tighter gaps work much better for performance.
Old Sep 9, 2003 | 03:15 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
If your running the stock setup(ie wires, coil, etc) the "stock" gap will probably be your best bet. If your running anything aftermarket for the ignition, then you'll want to go with a larger gap..
Old Sep 9, 2003 | 11:27 PM
bigals87z28's Avatar
Car: Check The Sig
Re: Plug gap?? Quick one
depends on the plug and what company its from. Range from .35 to .45 is good. It would only cause knock and ping if the plugs were not right for the car, i.e. you got the wrong plugs. What kinda plugs did you get and what model?
Old Sep 10, 2003 | 06:50 AM
Car: 91Z
They are AC delco, but I will have to get back to you on the part #.
Infested
May 22, 2018 11:56 PM
Thornburg
Sep 1, 2015 03:39 AM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
