code 36
Old Mar 19, 2004 | 09:26 AM
blackroc68's Avatar
code 36
Problem my 383 tpi has check engine ligght code 36 mass air burnoff, i replaced all relays burnoff,power, even tried new massair sensor no luck also ecm and connecters on relays. can an aftermarket hypertech chip be the cause.
Old Mar 19, 2004 | 05:54 PM
wilnuts88's Avatar
Car: 1988 IROC-Z
Engine: 385 Miniram/Holley HP EFI
Transmission: Probuilt TH-700R4
Axle/Gears: Moser 12bolt 3.55
code 36
I have the same problem with my 88'. I also have a hypertech chip and I have tried the same things you have. Switching the subject, what does your 383 consist of (cam, heads, etc.)?
Old Mar 19, 2004 | 07:56 PM
blackroc68's Avatar
my motor is a 383 etec 200 vortec headed ,scoggin dickey tpi.i have a zz9 roller cam comp pro magnum roller rockers
Old Mar 20, 2004 | 12:24 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Check the oil pressure switch
and do a search- you will find alot of threads about the subject.
/N.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
