twin blade vs. single oval blade
Old Mar 24, 2004 | 08:15 AM
Firebreather's Avatar
Car: 1991 GTA
Engine: SuperRam 350
I installed a SuperRam not too long ago and I'm still stuck with the 48mm TB. I can have it bored out to 52mm or into a single oval blade TB. I have to measure to know what size would it end up being as a single blade unit. What's the difference between the twin blade design and the single blade? Should I keep the twin blades? Is there a difference in flow or intake manifold matching or something...? Thanks
Old Mar 24, 2004 | 08:45 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
For your application, a 52mm tbody is best suited. A mono blade tbody is for a large cubic inch motor that needs some serious airflow.
The problem with a mono blade is that the transition from closed to open is very dramatic and can cause part throttle driveability problems.
www.geocities.com/dzperf
Old Mar 25, 2004 | 06:44 AM
Car: 1991 GTA
Well, I guess I'll just go with the twin blades then. THanks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
