Code 32 with new MAP sensor and EGR valve
Old Mar 31, 2004 | 01:56 PM
1bdbrd's Avatar
Car: 1991 Trans Am
what gives? im sure most have read of my problems, if not there are 2 threads about it a little further down.
well i replaced the EGR valve and the MAP sensor and im STILL getting code 32 even after i reset the ECU. whats going on here?
i also just replaced the o2 sensor with a brand new one and its still running pretty rich. any other suggestions?
Old Mar 31, 2004 | 02:43 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Does your EGR have a EGR temperature diagnostic sensor switch in the side of it? If so, you should check it and its wire harness, the EGR solenoid and its harness.
Old Mar 31, 2004 | 03:59 PM
1bdbrd's Avatar
Car: 1991 Trans Am
there wasnt any sort of sensor on the one i took off nor the one i put on. i just dont know what the problem is.
Old Apr 6, 2004 | 10:38 PM
Anthology83's Avatar
dude....check the vacuum lines for clogs......check the egr sol. for problems....and remove the egr and clean the ports
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Out-Cast
Aug 17, 2015 10:57 AM
squiggy2
Aug 9, 2015 09:30 PM
