Injector Size
Old Apr 9, 2004 | 12:09 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
Injector Size
How do you know when you got injectors that are too small on your setup. I was going over my recent datalogs and my Duty Cycle is running right aroung 97% in WOT in first, second third .. that cant be good..
Right now i have 24lb Lt1 injectors but i dont think they are enough
350
Mods are 224/230 comp xe cam
stealth ram
pro action port 180cc heads
1 5/8 headers
3" cat back
should i be looking for 30s or what?
Old Apr 9, 2004 | 12:52 AM
Morley's Avatar
What is your fuel pressure at? Could try running 46-48 PSI, 30# might be too big, maybe 26-28 if you can find them
Old Apr 9, 2004 | 12:58 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
~43.. ill try bumping it up a bit
Old Apr 9, 2004 | 05:30 PM
Canuck 88' T/A's Avatar
You might have ECM probs as well. I don't think injector size should be an issue, as 24lb'ers are good with an AFPR and stock TPI fuel pump to 450 hp. Good luck.
Old Apr 9, 2004 | 05:55 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I just bought a set of brand new 28.8# @ 43.4 psi LS6 injectors. Supposedly at 58 psi they're rated for 32#'s so I'm hoping that with a walbro pump and adjustable fuel pressure regulator I'll be safe.
My engine is a 383 with 11:1 JE flat tops, Edelbrock E-Tec 200 heads, Crane 109841 Powermax Hydraulic Roller Cam (Advertised Duration: 296°/304º Duration @ .050: 234°/242° Lobe Separation: 112°
Gross Lift w/1.6 rockers: .575''/.595'') 1.6 roller rockers, Holley Multi-port single plane intake, fuel rails, and 1000cfm 4v throttle body, hooker long tubes and 3" duals with x-pipe and dumps.
Should be good for 475-500 horse at the flywheel. Will these injectors be good big enough?
Old Apr 9, 2004 | 06:20 PM
I'm in the middle off a 383 stroker build right now. I am using Bosch 24lb injectors and they will be plenty. Plus, I don't have to mess with my ecm and my car will still remain a daily driver that will get better than 5 mpg! Seriously, don't go too nuts with big injectors, instead tweek your AFPR and pressure up some more fuel to them, see what you can get out of them before spending 300.00 plus bucks on injectors. You'll probably be suprised.
Old Apr 9, 2004 | 06:46 PM
drain89's Avatar
I had no injectors cause I was going from TBI, and these were $75 shipped. So I bought them. They're the new design 3 delphi/bosch injector which is supposed to be pretty good. I hope they work well with my application. I plan on doing alot of ECM tuning.
Old Apr 9, 2004 | 08:11 PM
Sorry, I guess I should have read about your car (TBI). I'm running TPI.
Old Apr 9, 2004 | 08:16 PM
drain89's Avatar
It had a 5.0 TBI motor but I scrapped that and went to the 383 with Multi-Port Injection. I know it's not TPI, but it uses the same style injectors and Speed Density ECM.
Old Apr 10, 2004 | 01:31 AM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
ls6 injectors should be flowing 28lbs at 58 psi.. i was going to go with a set but at the stock 43 psi they put out the same as lt1 injectors do..
i will save that money and order a wideband.. should make my life alot easier..
i should be in the 400 hp range tho.. i would think..
Old Apr 13, 2004 | 05:48 PM
BadAzzGTA89's Avatar
Car: 1989 GTA
Engine: LQ9
I am running the 24lb/hr accel injectors at 43psi and they do fine
Old Apr 13, 2004 | 10:04 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
with what mods.. i jacked my fuel pressure up today.. i think i might have a leaking/stuck injector as well
i think its ls1 time.. :lala:
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
