Starting problem Timing??
Old Apr 21, 2004 | 10:27 AM
john_iroc's Avatar
Car: 89 Iroc-Z
Ok , I changed my intake manifold and now i am wondering if i would time it first. In the tech articles it states warm up engine to normal running condition and then do the timing. So in my situation do I start my engine and then time or time it and then start my engine. Thanks!
Old Apr 21, 2004 | 10:52 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
In order for the engine to fire at all you need to have the base timing at least close to what it should be. If you remember the orientation of the rotor before you pulled the distributor, then you can put it back in just like it was. Then you should be able to start the engine and then set the base timing exactly by rotating the cap.
Old Apr 21, 2004 | 02:53 PM
john_iroc's Avatar
Car: 89 Iroc-Z
I thought I remember which way it came out and put it back but the engine won't fire up. So I should get it timed then instead of trying to get it the closest.
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
