help PLEASE new heads and intake,now it wont idle now i am lost
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
BINGO!! got it!help PLEASE new heads and intake,now it wont idle now i am lost
i installed new edelbrock 6085 heads and high flow intake with my slp runners, starts right up but when it tries to settle down begins to pop back up through intake when i give it throttle it runs fine, i replaced MAF, tripple checked timing, wires, iac, tps and hit the intake with propane and no vacume leaks no check engine light, even double checked valve lash and its fine no bent pushrods at all, i feel the concussion in the intake the plennum to be exact the best it will do is BARELY idle but still pops up through intake, also my new maf still has the screens so i know i didint damage it. man i am lost .:hail: thereat of the combo is unchanged
Car: '86 Caprice Classic
Transmission: TH-700, completely built
whats a "performance resource chip"?
maybe you need a new chip burnt because of your new mods.......
I'm just throwing out ideas
When you check with a timing light, what's the base timing set at? When you plug the module connector back in, what does timing jump to? Should only be about 20 deg. total at idle, and 6 deg. base.
Once you start getting into the heavier mods, really the only way to go is to pony up the couple hundred bucks and start burning your own chips. You'll save money over the mail order chips, and without logging data on your specific vehicle, there is no way to accurately gauge what your motor needs.
Car: 89GTA
Axle/Gears: B/W3:27
with the brown wire disconnected i got it set at 4 DEG advance, for some reason .....after sweatin all night i feel its a timing/ wires mixed up problem, i am gonna remove wires from distributer and check again the firing order . even if i advance the timing it still acts up? it ran dead perfect with the above combo, all i did is head and base swap... compression is about 9.8 to 1 now if that helps. from 9.3 what else would back fire through intake if not a wires/ timing.
man.. mods are like crack you know it might hurt but ur hooked and u do it anyway
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
All you did was a head an base swap? Dude, you got a new motor!
Whats the new compression ratio with the heads, or were they the same chamber size?
Also check for vacuum leaks.
-- Joe
-- Joe
Car: 89GTA
Axle/Gears: B/W3:27
well.. just checked wires and firing order and they all match up. could it be fuel pressure? when i remove the MAF ducting from the throttle body it goes into pig rich limp home and runs bit better, but at crazy high idle, i am about 43 psi i have the AFPR bucked off all the way up. could it be going lean at idle? would this make it pop? just throwing things out there.
engine now has 35k miles on the block
Car: 89GTA
Axle/Gears: B/W3:27
went from 67 to 60 cc , stock is 64cc .with a felpro .040 compressed thickness gasket per Edelbrock recomendations.
Car: 89GTA
Axle/Gears: B/W3:27
well turned out the bolts from the bottom of the runners to the edelbrock base were bottoming out. causing a horendous vacume leak. solved all that... did some adjustments: iac, tps, timing. and bam! greeted to a nice 750 rpm american V-8 rumble (made me wanna sing, "oh say can you see, by the dawns early light") anywayz well worth the 3 weeks of headaches. through all my research on here i never heard of that problem with the edelbrock base with SLP runners.
Car: 91 Z28
Transmission: 5speed
If its been beat to death (email it to me) sorry I have never heard of it.
Thanks man I have a pretty similiar situation I am dealing with right now and its driving me nuts
It's a method of artificial enrichment. If you have a vacuum leak, the propane will get sucked into the manifold and the RPM's will go up (or down, depending on state of tune). If you have no leaks, RPM's will remain steady. You could use ether, or really anything that is flamable.
1 Post
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Re: BINGO!! got it!help PLEASE new heads and intake,now it wont idle now i am lost
Car: 89GTA
Axle/Gears: B/W3:27
yep like said above^ i use propane or even a a spraybottle with gas. around any "suspicious" areas and in my case the rpm's will rise about 2-300 for a moment. then u can pinpoint a leak. hope this helps. by the way can some one run my combo through desktop dyno to give me an estimate of power?
Car: 89GTA
Axle/Gears: B/W3:27
the numbers listed are from the old combo at the top.
1 Post
Engine: 350 HO
Axle/Gears: 336
Originally posted by onebinky
Now this one I'm not familiar with
Care to share?
Care to share?
