looking for a distributor
Old Jul 13, 2004 | 10:16 AM
wako29's Avatar
Car: '86 Caprice Classic
Transmission: TH-700, completely built
I need suggestions for a distributor. The thing is, I am about to put in my crate 350 (~300hp) in my '86 Caprice right now, and just run it on a carb. However, later on, I am going to convert the motor to TPI. Doesnt' the TPI require a "low-profile" distributor or something? I just want something that will work with the TPI when I install it.
anyone have any suggestions? Thanks in advance.
Old Jul 13, 2004 | 12:00 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you're going to carb'ed, and assuming it won't be ECM controlled, then you'll need two different distributors.
Get a vacuum advanced HEI from the pre-80's GM to run with your carb setp, the dizzy you'll use with the TPI will be ECM controlled and all advance will be cnotrolled via ECM and module.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
