Engine Identification
When I bought my car the guy I bought it from said that it was a 305 TPI but a 350 TPI was swapped in. Is there anyway I can tell if he was telling the truth? Ive tried to look down behind the head to see if it says 5.0 or 5.7 but I cant see down there well enough to see anything. Any ideas? Any help is much appreciated. Thanks.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
There are also casting numbers on the side of the block, and on the head deck just in front of the pass. side head. Go to mortec.com for a full listing and pics of where the casting numbers can be found.
Or you could use a flashlight and a mirror to look behind the head.
Or you could just pull one of the heads and measure the bore.
Or you could pull the oilpan and measure the bore from the bottom.
Car: C-20
Engine: 260 boat anchor Mexican 350 (crate) TPI (MAF)
Transmission: THM-400 I turn 3500 (which is where my pos engine's power starts droping off) at 80 I need a 4L80-E
Place your foot to the floor if nothing happens, then it is a 305
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Originally posted by subliminal
As I said above, I cannot see behind the block to get the casting number. I was wonder if there was any other ways of telling a 305 from a 350.
Don't have one? Just pull a head and measure the bore diameter.
Maybe stretching a bit to see that casting number isn't so hard after all?
84z96L31vortec
Aug 20, 2017 12:16 AM
casting numbers, or go to mortec.com
