TPI Help ???
Car: 87 Z28
Transmission: 350 Turbo
TPI Help ???
I am in the process of swaping a maf tpi setup off an 85 305. My camaro has a mid 70's 350 in it. I plan on using a set of summits new double hump casting. What kind of injector should i use. Also does any one have any cam recomedations. I am also having motive burn me a chip. What else do I have to do to make the 305 tpi set up work on my 350.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I dont mean to sound sinical ( I know learn to spell) . But how are they makeing you a chip ...without knowing what cam you got ?If I were you ....I would try and get all the hard data on your setup ....like flow numbers and stuff like that. Thennnnn go to a reputable cam company ...and ask THEM what cam you should run . Off the shelf chips are really crappy. I would learn to make my own. It has been said here that you can;t really make a chip over the phone...they need to check out what the car is doing via datalogging. then make a chip based on the data. This usually tales more than one trial and error period. If you do end up getting a chip made over the phone ...your car may run ...but the tune will be less than optimal ....and may cause issues down the road ...
just my .02 hope it helps
Sanjay
Aug 12, 2015 03:41 PM
