am i doing this right?
Old Jul 13, 2005 | 09:57 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
1.Start car adjust fuel pressure.
2 shut off car put on gauge.
3.Unplug vacuum and check psi.
4. shut off car unplug gauge
5. put vacuum back on
6. start car
7. adjust fuel pressure again.
Wanting to know if this is the right way to adjust fuel pressure.
Old Jul 13, 2005 | 10:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would connect the gauge, disconnect the vacuum hose and plug it, start the car, adjust the pressure to the 43.5 or whatever, shut off the engine, then disconnect the gauge.
Old Jul 14, 2005 | 07:32 AM
kevinc's Avatar
Car: 1982 Z28
Re: am i doing this right?
6. start car
Not sure why you're adjusting fuel pressure after you've removed the gauge...how do you know what your adjusting it to w/ no gauge attached?
1.) Attach gauge.
2.) Disconnect and cap vacuum.
3.) Start car.
4.) Adjust fuel pressure.
5.) Shut off car.
6.) Remove gauge.
7.) Reconnect vacuum.
Old Jul 14, 2005 | 03:10 PM
Engine: l98 350 tpi
can i plug the vacuum with my finger?
When i plug the vacuum it does not change the psi, i wasnt sure if it supposed to change or not.
Old Jul 14, 2005 | 04:26 PM
kevinc's Avatar
Car: 1982 Z28
If you adjust the fuel pressure to 45psi w/ no vacuum connected to the regulator, it should drop to ~36 or so PSI when you re-connect the vacuum to the fuel pressure regulator...depending on how much vacuum your engine pulls at idle.
Old Jul 14, 2005 | 08:59 PM
Engine: l98 350 tpi
ok, i understand, i tried what you guys said and it works. I set it at 43.5. thanks alot for the help.
