MAF relays
Old Sep 17, 2005 | 08:25 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
MAF relays
anybody know where under the hood the maf relay & maf burnoff relay are located. 87 305 tpi.
Old Sep 17, 2005 | 08:31 PM
Kwiksilverz28's Avatar
Corner of the engine compartment, on the firewall, in between fender and master cylinder.
Old Sep 17, 2005 | 11:42 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
This might help...
Old Sep 19, 2005 | 11:57 AM
RGV 89 GTA's Avatar
Car: 2001 SS/1989 GTA
would this be the same on a 89 GTA TPI 350.
Old Sep 19, 2005 | 02:29 PM
Car: 92'Camaro RS
Engine: a loud one
I have a harness from an 89' in my car and it's all a spot on match.
Old Sep 21, 2005 | 03:14 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
If it helps, the relays are interchangable.
Old Sep 21, 2005 | 08:01 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Actually there not. Same relays, different part numbers. I thought you could too, but I couldn't, now I see why they are different part #'s.
Old Sep 23, 2005 | 09:36 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
Originally posted by david roush
This might help...
Are those labelled correctly? I ask because I bought a new burnoff relay from the dealer and the p/n matches the book. However it looks exactly like the one labelled for the fuel pump.
I know the power is labelled as such. I'll just unplug one of the others and see if the car starts. If not I know which one is the fuel pump relay
Old Sep 24, 2005 | 10:44 AM
Well I did mean the power/burnoff relay, anyway mine were two different part numbers and both worked.
Old Sep 24, 2005 | 02:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
David, it's only polite to thank or give credit for that or any pic that you use that belongs to someone else.
Thanks Vader.
re:relay interchangability
Some years have the two MAF interchangable, some all three are interchangable, some only one MAF and the f/p interchangable..
Old Sep 25, 2005 | 11:07 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
My 89 has the newer style oval relays for the power and burn and the older style square one for the fuel pump.
My 86 has three square relays, all different part numbers, they are not interchangable, I found this out the hard way, the motor ran but kept stalling.
Old Sep 28, 2005 | 06:21 PM
camaroken's Avatar
Car: 86 k5 blazer, 88 iroc-z, 2000 caddy sts
Engine: 2 305's 1 northstar v8
Transmission: 2 700r4's
you know I've got the same issue and reading this thread got me more confused LOL. car runs rich, won't idle right, about 1500 rpms hot or cold. codes for rich, and mass air flow and burnoff codes. i'm a mechanic but these tpi cars are confusing, due to year to year differences. mine is an 88 tpi 305 iroc z. any ideas to help?
Old Sep 28, 2005 | 08:34 PM
I have diagnostic charts for the codes if you need to know how to track the issues down....
Old Oct 2, 2005 | 05:48 AM
camaroken's Avatar
anything at this point. but it seems with the codes i have the problem could be any one of the three causing it but which one do diagnose first. meaning the rich o2 code could be set beacause it is running rich, but is the maf causing it too run rich or is it the o2 itself?or the ecm could be causing all the codes. I'm little stumped on which way to go
Old Oct 2, 2005 | 08:07 AM
Vader's Avatar
Exactly which codes are stored?
It seems a 45, a 36, and either a 33 or 34.
I would not dwell on the rich O² just yet. Once the ECM sets a MAF error, it will operate the engine on Backup Fuel parameters, when tend to be quite rich. Repair the MAF circuit problem, and the O² may settle out as a result.
Old Oct 3, 2005 | 08:37 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thnks to all who replied. I finally gave up, took it to a specialist in wiring & computer diagnostics. He found a couple bad terminals in ECM plug & a frayed TPS wire. Thanks again.
Old Oct 4, 2005 | 05:17 PM
camaroken's Avatar
thanks vader, the codes are 33,34, and 45 which is maf, maf burnoff, and 02 rich.
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
