SLP CAI for Speed Density
Old Oct 28, 2005 | 04:42 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Anyone who this this setup did you notice any gains? Also what exactly comes in the kit? Do you get all new air ducting or just the new filter box? Thanks in advance. Pictures would be great from those that have it.
Old Oct 28, 2005 | 05:52 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
It comes with another factory duct tube to my surprise. I was just as well off to cut some extra holes in my round air cleaner canister I thought.
Old Oct 28, 2005 | 07:06 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I made a cold air intake with PVC piping. I'll snap pics when my car is assembled, but it took 2 90* bends and 3 feet of piping, total cost was like $8. Then I cut a hole where the air cleaner sat before so the cone filter could get air that blows past the passenger side fog light. I didn't notice any difference but I did a few mods at the same time so I'm not really sure. But it now: 1. gets cold air, 2. has less restriction at bends and larger piping, 3. looks better.
Old Oct 28, 2005 | 06:18 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The problem with the SLP cold air package is it uses the factory rubber ducting. IMHO that is a big part of the air intake restriction.
Old Oct 28, 2005 | 06:55 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I had one before on my IROC, it's not worth the money. Just make your own, or if you prefer the OEM look just buy their airbox and use the stock ducting.
Holloman, huh? I was stationed there before...
Old Oct 29, 2005 | 06:02 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Thanks for the ideas. You were stationed here huh? When? And what did you do?
Old Oct 29, 2005 | 12:49 PM
IROCZZ3's Avatar
Car: 87 Buick GN
I was there from 93-97. I was a helo crew chief with the old 48th rescue squadron, but the 48th since closed in 1999. I was just in Alamogordo passing through this past June....I see the mall still sucks, Morris machine is still around, and why on earth did they put a Lowe's and Home Depot RIGHT next to each other. Oh well, I still enjoyed living there. I sure miss those open roads.
Old Oct 29, 2005 | 05:00 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My SLP intake setup came with the air tube, 2 air boxes, 2 K&N Filters, radiator hose, thermostat housing and the short air intake tube that goes on the throttlebody.
I don't have anything to compare to on that car since it was a carbed car and I converted to SD TPI with heads and cam, full exhaust and the SLP intake all at the same time.
Old Oct 31, 2005 | 07:31 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Thanks for the pic. Yes Alamogordo is still pretty much the same old small town it was back then probably. Theres a Chillis now!!
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RGB2015
Sep 20, 2015 09:26 PM
89fast5oh
Sep 8, 2015 09:55 AM
