58MM AIR FILTER PROBLEM
Old May 24, 2006 | 06:23 PM
noelito1991's Avatar
Car: 1991 gta trans am
Engine: 355
Transmission: TH400
whats up everybody, does anyone know or recommend a air filter setup for a b&m 58mm throttle body setup. i tries to use my k&n that i had on my old stock throttle body, but it won't fit the 58 mm one. does k&n sell a setup or does anyone know of a good ram air setup where the filter is connected to a tube and then that goes on to the throttle body, please send me some of your ideas guys, the car is a 91 gta trans am.
Old May 25, 2006 | 01:02 AM
robert1's Avatar
I thought that K&N sold a biger one too for the 58MM.
Old May 26, 2006 | 03:07 PM
TKO500's Avatar
Car: 91 B4C, 17 C7 GS, 16 Denali DMax
Engine: LS3, LS3, LML
Axle/Gears: 3.23, 3.42, 3.23
I am using the K&N cone air filter that mounts directly to the throttle body on mine. The part number is RC5000 or something like that. I know the last 4 numbers are 5000.
It fit on the stock throttle body and on the 58mm BBK.
Old May 27, 2006 | 10:49 AM
Engine: 355
Transmission: TH400
thanks for the input guys, the only thing that i'm worried about is it hitting my radiator hose on the right side. Did you have a problem at first with the hose or is it just my luck.
Old Jun 3, 2006 | 08:11 PM
camarojunkie77's Avatar
Car: 1977 camaro z28
My filter comes pretty close to my radiator hose also.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Derick15
Sep 17, 2016 05:28 PM
theurge
Aug 21, 2015 12:46 PM
