What is "siamesing'
Old Nov 7, 2006 | 01:28 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
What is "siamesing'
I'm familliar with Porting, but I've never heard of siamesing.
Could someone explain this to me, and maybe list some of the pros and cons associated with it.
Old Nov 7, 2006 | 01:44 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Basically, Its taking your stock OEM runners
from your TPI unit, and welding patches of
aluminum to "join" the 4 individual runner tubes
together. After its complete, you will have 2
large runner tubes on each side of the unit..
Instead of 4 tubes.. I dont reccomend
fabricating your own.. as after-market
siamesed runners are readily available.
If you scan down to the :
"Post Your TPI paint scheme" Thread,
Tenpin posted a picture of his Siamesed
TPI 305, that will give you a better idea
of What I just said.
As for performance, Its not a "Must-have"
when building TPI motors, but.. They sure
can give some up-top ponies if matched
with the correct intake manifold
Old Nov 7, 2006 | 01:49 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Old Nov 7, 2006 | 01:51 PM
[R]ogue's Avatar
Car: 84 bird
top left would be what siamesed intake runners would look like
top right would be what siamesed cylinders would look like ( like a 400 )
bottom left and right would of course not be siamesed or basically share a wall to keep it simple
siamese would save space, making siamese where there is none - such as intake runners would increase the volume, in the case of cylinders in the block siamese would be a potential weak spot and in case of 400 help it run hot
Old Nov 7, 2006 | 01:54 PM
TPI's Avatar
There we go, that should do it!!
Old Nov 8, 2006 | 12:03 AM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
Here is an inside pic of my ported Siamesed SLP runners
Hope that hepls
Old Nov 8, 2006 | 02:44 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Thanks everyone. They look like they were cast that way. To wld them together and have them look that good seems to be impossible.
Old Nov 8, 2006 | 04:27 AM
TPI's Avatar
Well actually, since the runners are made of high grade aluminum,
you can TIG weld to fuse the aluminum together. There was a few
pictures awhile back of someone who did this, and looked rather cool.
A properly ran TIG bead looks very pleasing to the eye..
But, Thats why I stated before its much easier to purchase a
set of aftermarket runners of your choice.. Im sure there is a ton
of topics on the matter.. use the search function.
Nice close-up shots Stubbs
Old Nov 8, 2006 | 10:17 AM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
yea i was doing mad reaserch on this i found out you can add mad horsepower for cheep. if you get a new bbk 58mm TB and SLP runers, you can siamese your plenum, runners and intake manifold to get reat power. like people were talking anywere from 40-60 hp at the wheels. dunno fi this is true but il find out. forting your runners and plenum and intake is really easy. go slow, and you will be done in a week. do you know about your restricive plates in the plenum? do a serch in thsi you wil learn alot like i did!
Old Nov 8, 2006 | 01:49 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
58 mm tb would be a waste of time and money @ that power level. The stock tb doesnt become an issue until ATLEAST 400 fwhp
Old Nov 8, 2006 | 06:50 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
I did all of that, I bought a second plenum and had the plenum fully ported(including opening up the sides so that it is now 4 large openings instead of 8 small ones, its exactly matched to the opening in the pic I posted of the ported runner) and matched to my 58mm TB, the SLP runners were ported and gasket matched to the plenum and also to the ported TPiS Big Mouth lower intake manifold. Total cost(including the port work but not including the TB) was almost 1100 dollars. I never had it installed and now it appears I may be going with a MiniRam since it will soon be EGR compliant so I can run it legally I will most likely sell the full modded TPI setup(no TB), I'm looking to get 1000 for it if your intrested.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
JHX
Sep 3, 2015 07:55 AM
Night Hawk
Aftermarket Product Review
Apr 13, 2001 02:12 AM
My90Iroc
Apr 12, 2001 09:52 PM
Ward
Dec 3, 2000 06:51 PM
