Where does this vacuum line go
Old May 1, 2007 | 07:01 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Well I replaced all my top end gaskets in my 87 305TPI and I am left with one vacuum line that I dont have a home for.
There is a vacuum can behind the passenger headlight with two lines coming off it, one small and one large. The small one goes a couple feet and then V's off into two small lines. One small line goes to a plastic vacuum tube that comes out under the throttle body on the passenger side. The large line goes to the throttle body. Where does this second little vacuum line go??
Thanks,
Dave
Old May 1, 2007 | 07:21 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Where does this vacuum line go
check return line to fuel tank hope thats it jimmy
Old May 1, 2007 | 08:19 PM
iroc88lb9's Avatar
return line to fuel tank will be on the charcoal cansister....NOT the vaccum ball.
do you have cruiscontrol? i am pretty certain the vaccum ball is for your cruise control system.
Old May 1, 2007 | 11:40 PM
Car: 89 GTA
Axle/Gears: 4.10
It looks like one goes to fuel tank and one goes to pressure valve.... I'm not sure where those two fittings are though?
Old May 1, 2007 | 11:42 PM
Car: 89 GTA
Axle/Gears: 4.10
http://www.autozone.com/images/cds/g...3d8016381e.gif
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
