How the hell am I running w/ an LT1?
Old Dec 11, 2000 | 07:54 PM
89FormulaL98's Avatar
i have a 89' Formla 350 w/ the mods listed below... i might have more cuz most of the stuff was on it when i bought it... anyways im running close to my friends 94 fomula and its fast... can sombody explain this?
Old Dec 11, 2000 | 08:13 PM
theformula's Avatar
What tranny is in the formula?
I've run with everything from LT1 vettes (95 and 93) to camaro LT1 6speeds. Pulled on the 95 vette and LT1 6speed from a roll. 92 pulled from me.
I only had SLP exhaust and a K&N filter at the time.
No one ever believes me though.
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Old Dec 11, 2000 | 10:40 PM
89Formula350's Avatar
Same thing here. I've raced 3 LT1's and beaten them all, two six speeds and one automatic.
89 Formula 350 WS6-BONE STOCK (not for long)
60FT-2.00
1/4 ET-14.25
1/4 MPH-96.07
Old Dec 12, 2000 | 01:56 AM
DON 88T/A's Avatar
You can run against anything that is poorly driven....
My mid/high 14 second (not anymore) T/A TPI with 5.0 auto,single cat,minor mods,stock exhaust beat several 13 second cars on the street.
Key word street.....anything can happen there.
Plus people don't take thirdgen's serioulsy....L98'S run mid low 14's 96-97mph stock especially speed densitys.
LT1's run 13.7-14.2 99-103 mph....
On a low speed roll the L98 hangs with/exceeds the LT1 with the torque...but the LT1 will catch up.
So a L98 with minor mods can run/edge out a stock LT1.....
Old Dec 14, 2000 | 02:08 PM
theformula's Avatar
I have several tests for 93/94 LT1 f-bodies running high 14s. My car runs faster stock (14.5@92mph) in Hot Rod magazine (well not my car, but one just like it hehe).
All my races were from a roll, not a lot of talent is needed for that especially since the camaro LT1 I dogged was an auto.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body, runners,intake manifold,cam, and heads.
Old Dec 16, 2000 | 07:16 AM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
My friends '96 M6 TA could only pull a best of 14.9 at mid 90s mph when he bought it. He tuned it up and changed the fuel pump and was pulled a best of 13.6 at 102mph.
LT1s are just like any other engine, if they're not tuned or have a small problem, they're not going to make the HP. Tune them and they're a beast.
Sparks a flyin'
Old Dec 16, 2000 | 04:39 PM
Formula9's Avatar
'89 Formula 350 dual-cat,T-Top
K&N, TPIS airfoil, Hypertech AFPR, ADS injectors,March pulleys, Edelbrock TES headers, Flowmaster cat-back, B&M shift kit, Performance Resource chip, SSM SFCs
Best:
1/4 ET:13.670
MPH:100.97
1/8 ET:8.773
MPH:79.57
60':1.974
13300mi, 245/45-16 BFGoodgrich Comp T/A ZR
Old Dec 16, 2000 | 04:52 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
What Sparks said!
Old Dec 17, 2000 | 06:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I belive it the early lt1s were slow.
Old Dec 17, 2000 | 10:29 PM
DON 88T/A's Avatar
I have seen 94/95 LT1's run low 14's/occasional 13.9 stock.97-99mph.
My one friend ran 13.7 stock(96 manual z28).....13.2's 107 with petty sh#t.
They will run once you uncork them,like the L98.
14.9's are horrible for an non convertible LT1.....that represents poor driving(usually the case in car mags),or a poor running car.
Plus remember the build quality is erratic with these cars,thus one could be a screamer from the factory,the next one could be a turd.
Old Dec 18, 2000 | 10:21 PM
MrJ's Avatar
MrJ
Actually, the early LT1s were some of the fastest, due to the speed density setup and different ratios in the T-56. Maybe .1 or .2 quicker than the 94s or 95s.
gixxer92
Apr 12, 2022 12:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
codeysabatini
Nov 10, 2015 04:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
CatmanFS
Sep 19, 2015 09:00 AM
