New engine which chip?
Old Dec 28, 2000 | 04:05 PM
T-Tops's Avatar
Recently replaced my blown 305tpi and put in a 355tpi. I know about the different size injectors and the knock sensor but from what I have read here it seems that I'll need to replace my chip also. So whatever chip I decide to go with, do you order one for a 305tpi which is what my car originally had or order one for a 350tpi?? Maybe this should be obvious but I'll roll with the punches since I'm the new kid on the block!!
Old Dec 28, 2000 | 06:21 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do you have an automatic or a stick? If you have an automatic, get the 350 automatic chip. If you have a stick, there is no 350 5-speed chip. But you can use the 305 5-speed chip, or get a custom chip. There isnt a "magic" off-the-shelf chip that works with every car. For that, you need to get your car dyno-tuned and have a custom PROM burned.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
