Code 33 on my '91 SD TPI
Old Jan 6, 2001 | 05:07 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Well guys, I was telling you about the stumbling problem I was having sometimes. Now it will idle down really low sometimes and then die soemtimes too. When it idles down I try to give it more gas but it seems to have no effect, but sometimes pulls through. Anyways, I haven't checked fuel pressure or anything yet but I got a code 33 a few minutes ago and I checked it and it said HIGH VOLTAGE/LOW VACUUM at MAF or MAP. I have a MAP of course with my SD TPI so is there any way to check the MAP out or what? I'm going to go check to see if there are vacuum lines on the MAP(I can't remember). Any suggestions on what to do? THANKS for any help!!!
'91 GTA:5.0TPI-5-spd, Hypertech Stage 2 chip, 160stat,!TB,!Cat, K&N, Flowmaster muffler, Accel Coil,TPI Air Foil, 1LE Alum DS, poly-tranny mount, KYB's all around, & a Hotchkis Strut tower brace.
Mods in progress:
-L98 w/ZZ4 cam/springs
-Edelbrock headers
-3" flow setup
Future:
-T56/heavier clutch
-Hurst or Ripper
-4.10's
-Ram Air II Hood
-1.5" Springs
-Rebuild suspension!
Others:
-39 Chevy coupe
350/350/3.55posi
-52 Chevy p/u
-77 Bonneville 400PONTIAC/400turbo/posi
Original 50k mile 2 door... Gramp's old car!
*** Gotta love those Poncho's***
Old Jan 6, 2001 | 06:38 PM
rondubbs's Avatar
my suggestion would be to change your map relays first and if that dosent work, buy a new map.
Old Jan 6, 2001 | 11:44 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
OK, but where are my MAP relays at? I guess this would be similar to replacing that cheap MAF burnoff relay compared to buying that EXPENSIVE MAF sensor. Hopefully those relays or MAP will fix it. Where are those relays though? THX! Anyone else??? Also, is there anyway to test the MAP semsor?
Old Jan 6, 2001 | 11:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uhh... what MAP relays? My guess would be a crack in the vacuum line that goes from the plenum to the MAP sensor.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 7, 2001 | 10:35 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
So are there any MAP relays? I'll check those vacuum lines. Isn't there one between the MAP and FPR also? It might be plastic though. Well, I'm open to more help!! THX so far!
Old Jan 7, 2001 | 12:34 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
There are no MAP relays. Definatly check the vacuum lines from the Plenum to all the accessories they go to.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 9, 2001 | 07:33 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
THX guys. I think that the reason for the code is because it was idling down to like 400 or so and this caused very low vacuum. I cleares the codes and drove it some more but it hasn't returned. Me and my dad looked at it last night and the IAC,TPS, and MAP vacuum lines were fine, but the EGR may be screwed up. I think this is why I had such a horrible idle sometimes and I think it could cause stumbling when it screws up. What you guys think? THX! Later
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
