i need some expert advice
my camaro is running 13.80's right now im am looking to step the car up so i can run th EFI 13 NMCA class so i need to get it down to atleast 13.20 I have some money to spend and i am open to all opinions. Right now the car has a performance resource chip, a borla cat back, and gutted air boxes with k&N filters, and i run th car on some m/t slicks. It is also pretty heavy 3650lbs so any weight saving tips would come in handy too. keep in mind i still have to drive the car every day on the street
91 Z-28 L-98 Black stock 14.20 @ 97
I would say that a good set of 1 3/4" headers, a 2400 RPM or so stall converter and maybe a cam would get your car for sure down to the low 13s. Also port your plenum and base and get a good ingnition set up.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
HoosierinWA
Oct 7, 2015 10:15 AM
