Whats the Difference between a 305 & 350 TPI?
Old Feb 18, 2001 | 11:21 AM
WinkM23@aol.com's Avatar
Hi,
My question is, Whats the Difference between a 305 & 350 tuned port injection system? Im just talking about the fuel injection system, not the engines. I hear that it is just the fuel injectors (305-19#, 350-22#), is that the only difference? Will the 305 tpi fit perfectly on a 350? I have a 305 tpi(1988 iroc 5 spd), and im gonna buy an 88 350 carbed that needs to be rebuilt. Im planning on putting about $1200 into parts for a 383 stroker kit. Anyways, I was wondering if i could use the tuned port from the 305, on the 350 if i get new injectors?
Thanks,
Matt
PS if anyone has info on building a low budget awesome 383 stroker, please email me or reply to this with the info.
Old Feb 18, 2001 | 01:13 PM
The ODB's Avatar
Yep,
and my 383 is definately budget.
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Feb 18, 2001 | 05:09 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Knock sensor is different also.
"Perfection is a trifle dull. It is not the least of life’s ironies that this, which we all aim at, is better not quite achieved."
-W. Somerset Maugham
Old Feb 18, 2001 | 05:29 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Here's a question I've been waiting to ask, and now's as good a time as any. Is the wiring harness in a 305 TPI the same as a 350 TPI??
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR or Trick Flow heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
Old Feb 19, 2001 | 01:29 AM
Omar's Avatar
The wiring harness should only be different when switching from MAF to SD, or vice-versa. 86-89 305 and 350 TPI's will be the same, and 90-92's will be the same.
1989 IROC-Z 5.7L
Wade787b
Sep 29, 2015 01:15 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
