what does it mean to gasket match?
Old Feb 26, 2001 | 11:21 PM
hookin88formula's Avatar
probably a stupid question but just wondering since i have my plenum and my runners off polishing them right now. just finished the plenum extension today looks awsome!! will have pics when i get my digital camara. thanks for any help
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Feb 26, 2001 | 11:24 PM
theformula's Avatar
gasket matching means placing your runner gasket over the runner holes (or any gasket/holes for that matter) and tracing around with a pen or pencil. Then you port all the way to those lines. Basically you are getting all the holes matched up exactly with the gaskets. If you look at the runner holes, you will notice some of them slightly vary in size. I never did it. The most important thing to remove when porting the plenum is the cast wall right behind the twin openings.
Hows the polishing coming along? Make sure you remove all the "cast" and remember to take your time on 400grit!
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 26, 2001).]
Old Feb 26, 2001 | 11:53 PM
the polishing is looking great i have a mirror finish just like u said i would!! might go back and hit 400 all the way up again to see if i can bring out the shine just a tad more!
sheachopper
Jul 31, 2019 11:27 AM
rusty vango
Sep 29, 2015 02:44 PM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
