*Accel GP?*
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
*Accel GP?*
Is there a group purchase going on for an Accel superram plenum and runners right now? If there is what is the cost of them and how long will it be for?
Car: 89 IROC-Z
Engine: 383
I don't know if there is one going on right now, but if not you could probably run it yourself. I ran one on the same parts last year. It's really no big deal. You can try contacting someone like PaceParts for pricing.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, either AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
***** Flyby: (n) When you let off the throttle after beating a ***** Racer by a few car lengths and he then blows by you in an attempt to convince you he really won the race.
--RPM Racing--
There is one getting started currently. Check out this post.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
1992 TA TPI setup
