GOING TPI
Old Mar 4, 2001 | 12:23 AM
SHARP89RS's Avatar
GOING TPI
Ok since no one in engine swapping has anything to say i'll bring my questions here.I've currently got an 89 RS with TBI i also have an 89 IROC hit hard but with a good tuneport in it my first question has anyone done the TBI to TPI swap in here and also what else is involved in doing the swap besides changing ecm,fuelpump,wiring,new throttle cable,detent cable and cruise control cable i've already taking the top end of the IROC and don't wanna tie my car up with the swap so any help would be great..
John 89 RS "Damn to much money tied up in the car to have TBI so like they always say you don't like it change it..
TPI KICKS AS*
Dale Earnhardt you are not forgotten!
Old Mar 4, 2001 | 07:41 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Have you read the tech articles here?
This is what you want.
https://www.thirdgen.org/newdesign/tech/tbitotpi.shtml
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Mar 6, 2001 | 12:01 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Right now i have a 350 with a holley on it cause my 305 took a crap, didnt know anyone with a tpi system and didnt have money. Well about a month ago, my girlfriends brother told me he had one, and i bought it off of him, cause ive always wanted tpi, i hate carbs, there such a pain and bad in gas and starting. I know the tech page shows how to switch from tbi to tpi speed density, but what about switching to mas air, which is what i bought.
Old Mar 6, 2001 | 12:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Switching to MAF is pretty much the same thing. If you can do one, you can do the other.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 6, 2001 | 09:37 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
but isnt there different sensors that you will need, and stuff like that, like i believe theres no knock sensor, or do you still have to use a hydraulic roller cam
Old Mar 6, 2001 | 12:04 PM
Kevin91Z's Avatar
Yes MAF cars use a knock sensor, but its a different type than the speed density cars. And all our cars from 87 and up use roller cams. 85 and 86 engines dont roller cams, even with TPI. Where do you come up with this stuff?
Old Mar 7, 2001 | 09:44 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
so can i use the knock sensor off my tbi.
Old Mar 8, 2001 | 01:27 AM
Ski89Z28's Avatar
If the knock sensor is to a 305 NO!
305 and 350 knock sensors are different, too!
Old Mar 8, 2001 | 04:46 PM
Kevin91Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mac:
so can i use the knock sensor off my tbi.</font>
No, you need the knock sensor off the TPI car.
Old Mar 8, 2001 | 08:23 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
why do you always say the 305 and 350 knock sensors are differant? I looked it up at work for my 88 305 tpi and 350 tpi and both had the same part # did gm mess up? I work at a gm dealer and I find it odd that they have them listed the same but, maybe you know some thing I don't also it would not be the first time some thing did not match right from gm
Old Mar 9, 2001 | 03:01 AM
Kevin91Z's Avatar
I dont know either. All my research says only the MAF and SD have different knock sensors, the engine size doesnt matter. But other people say it does matter. *shrug*
Old Mar 10, 2001 | 11:54 AM
NUN's Avatar
NUN
i think were getting brudel info on the tpi engines my mechanic says that the 305 and 350 engines are different tpis says there pretty much the same the only difference is the injectors and a prom
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
