ZZ4 Cam question
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
ZZ4 Cam question
how much hp would a zz4 cam put a near stock motor too with 96,something miles on it and a high-flow catback exhaust
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: ZZ4 Cam question
Not much for long, seeing as to how the stock heads won't take the lift of that cam without a bunch of work.
Car: '87 Iroc-Z
of course I'm going to put new springs from GM on it an cut the valves stems. Anyone else?
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I used it in a 305 with z28 springs and it worked just fine. my heads were also ported and polished but I think it would work either way
