How many successfully use an inline fuel pump?
Car: Jeeps
Engine: 1970 4 bolt 350, 19000 miles & TPI
Transmission: Tubo 350
Axle/Gears: 4:11
Hello,
I'm putting a TPI in my Jeep 350 and have read by some that an in-tank fuel pump is the way to go... My fuel tank doesn't have baffling, so I figure what is the point of going in-tank? It would be much easier for me to just install an in-line electric pump and drive with the tank above half.
Is there anyone here who is using an in-line pump to feed the tpi without troubles?
Thanks,
Jim
Thanks,
Jim
Re: How many successfully use an inline fuel pump?
I have the same setup in my YJ. I'm running an external fuel pump on the inside of the rear frame rail, I'm also running a fuel cell. in the tub behind the back seat.
I always keep a spare pump, as they are prone to failure from being submerged in water, or mud.
Even when my jeeps on its side, or on extreme angles, it will have fuel. This is the good thing about going with external.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
