TPI idle problem
Old May 7, 2001 | 07:32 PM
mrgto's Avatar
TPI idle problem
hi i got a problem. i got an 87 formula 355 with slp runnners headers and exhaust, tpis zz9 cam 24 lb injectors ported 202 stock casting heads the car runs rich cold then surges like crazy after 10 mins. i have set min air rate and tps voltage. i have tried several mass air sensors and a computer. a freind tells me it might be the stock chip not being able to handle the cam and injectors. if the problem is in the programming i would like to run accel dfi because i am not done changing my whole drivetrain/ engine combo if anyone can help i would apprecieate it. thanx
nate
Chris
1999 RA TA
Old May 7, 2001 | 07:35 PM
F22Raptor's Avatar
O2 sensor ok?
Ignition
timing
fuel pressure
Many many things to check
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
