getting the feed line out of a fuel rail
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
how do you do this or is it pressed in and need something special to get it out?
Car: 91 RS Texas B4C
Engine: 305 TPI (M.I.A.)
Transmission: T5 (M.I.A.)
Axle/Gears: 3.42 Posi
Re: getting the feed line out of a fuel rail
Wondering the same thing. It appears that my return line end-fitting was inserted into the rail and then the surrounding rail surface has a crimped area that serves to retain it. Surely there's some sort of seal between the rail and the tube end-fitting...o'ring perhaps? Getting it apart sure would make the job of painting the feed/return lines easier. Plus, if there is a seal I'd like to change it. Nothing in my manual indicates it's servicable as individual parts. Just references it as a rail assembly that includes the tubes....
