L98 ALUM. HEADS WITH GUIDES AND SELF CENTERING?
Car: Damn
Engine: This
Transmission: New Stuff
I bought a set of used L98 aluminum heads from a vette yard a while back. When i got them i noticed they had pushrod guideplates and self centering rocker arms.
I've read it isn't good to use both together so the pushrods don't bind. I've used them this way for over 5,000 miles now with no problem.
Anyway, When i buy roller rockers should I get self centering or save the money and get regular ones since i already have guidplates?
thanx
'88 RS (originally 2.8)
-350, .040 over, vette alum. L98s, stock tpi.
-305 injectors & chip
-TES headers & edelbrock cat back
-3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 356-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
thanx
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
get self-aligning. It is sooo much easier to deal with. IMHO it's a pain to screw with the guide plates, and then they still don't align as good as self-aligning. BTW-If you still have the centerbolt valve covers, you'll have to cut out about half the bracing inside the covers for roller rockers to clear.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
13.87 on the G-tech
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
non-self algiening roller rockers=guideplates
self algiening roller rockers=no guideplates
a lot of aftermarket heads don't need guideplates even if you have non-self algiening roller rockers.also you should use harden push rods with guideplates
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
[URL=http://www.street-dawg-racing.cityslide.com]http://www.street-dawg-racing.cityslide.com <A HREF="http://
[URL=http://http:/discussion-board.com/GreaterCincinnatiFBodyAssociation]http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/ TARGET=_blank>
[URL=http://http:/discussion-board.com/GreaterCincinnatiFBodyAssociation]http:/discussion-board.com/GreaterCincinnatiFBodyAssociation/</A>
[This message has been edited by 91banditt2 (edited May 11, 2001).]
Car: Damn
Engine: This
Yeah i have hardened pushrods.
OriginalOne: I got them from Taber Corvette Parts for $400 complete. Thier web site is www.tabertouch.com
shipping was about $35. I had them rebuilt before i used them. Tell me if i can help any further.
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
-3.73 gears, 700r4.
on a 2.050 60 ft.
(Damn the 2.8!)
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Vette heads use guideplates and self aligning rockers. Plus there is no grinding needed for full rollers and centerbolts. i am proof of that
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam
relocated battery
cold air
Hypertech chip
centerforce clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
a/f gauge
autopower rollbar
14.0 at 100 NA before heads
Juice and AFRs??......TBD
1991 Firebird
T-5 transmission
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
Hurst linelock
SLP cam
relocated battery
cold air
Hypertech chip
centerforce clutch
AFR 190s
a/f gauge
autopower rollbar
ambainb
04-25-2016 09:21 PM
1988iroc350tpi
08-14-2015 07:52 PM
