Paging Vader!!!!!
Old May 16, 2001 | 10:38 AM
kdvol's Avatar
Paging Vader!!!!!
Any suggestions on what to do next? I have replaced all the vaccuum lines, the MAF sensor, both relays, the connector, and the ECM. I have adjusted the TPS to .54 volts, and still the SES comes on intermittently and the car runs like crap. It may go off on it's own or if you shut it down. Sometimes it comes back on when you crank back up. BUT NO CODES!!!! Only 12(all clear) Is it time for the dynamite???
Old May 16, 2001 | 11:41 AM
leirch's Avatar
I'm not Vadar(damm..), he must know whats going on with your problem. You could always convert to Speed Density or somethin
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 16, 2001 | 03:14 PM
jovialevil's Avatar
Screw Dinamite!!! some of my buddies need a car to trash in their music video.... your could take out your aggression and your car would be famous!!!!
Old May 16, 2001 | 07:22 PM
irocbsa's Avatar
Have you checked all the wiring going to the MAF and the relays. This sounds like a good place to go next. Let me know if you need a trouble shooting guide. I'll try and type it up for you or send you a copy per US Mail. Email me if you need it. irocbsa@mindspring.com
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 17, 2001 | 11:09 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Sounds like more of a computer related problem. I've heard the same problem before but couldn't find the post in the archives on it.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 18, 2001 | 08:40 AM
irocbsa's Avatar
There is an active thread right now at the link below that should take you in the right dierction to check the wiring.
https://www.thirdgen.org/messgboard/...ML/002653.html
bsa
Old May 18, 2001 | 06:37 PM
speeddevil's Avatar
thanks for posting the link, i've been looking for that info but i guess i overlooked it...
Old May 18, 2001 | 08:38 PM
86Trans Am's Avatar
I am assuming you unhooked the battery while replacing all those parts? If not, you may want to try that.....just a thought though
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
Abubaca
Nov 5, 2016 12:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
