MAF screens Remove?
MAF screens Remove?
Should i remove my MAF screens on my 88' iroc 350. If i do so will it ruin the MAF sensor. Also what kind of gains will i get out of it?? I heard they are very restrictive. Any suggestions??
[This message has been edited by Fast Iroc-Z (edited May 22, 2001).]
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
you can remove them but make sure you have a good air filter like a K&N or accel. you will get about 50 cfm as for HP it depends on your combo.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
406
accel supper ram
afr heads
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
