runnin lean??????
Old May 19, 2001 | 12:16 AM
poncho9789's Avatar
runnin lean??????
Have any of you noticed or heard of any problems with the TPI leaning out one side (I think the 2,4,6,8) of the motor? What could cause this. The reason I ask is the block that I took into the machine shop had run lean and detinated on the 2,4,6,8 side of the engine. That caused the #4 cylinder to end up with a crack in it. Don't want that to happen again!!!!!
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Old May 21, 2001 | 12:30 AM
poncho9789's Avatar
anyone???
F-body-fan
Jan 12, 2023 01:49 PM
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
